Discuss
LG smooth top only 3 of the five burners are working
 in
Microwave Repair
We purchased an LG smooth top range in 2007, and recently two of the five burners have stopped working. Can
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » LG smooth top only 3 of the five burners are working
  #1 (permalink)
Old 11-04-2011, 06:49 AM
Junior Member
ojh6187 is on a distinguished road
Default LG smooth top only 3 of the five burners are working
Model Number: LRE30451ST   Brand: -other-   Age: 1 - 5 years
We purchased an LG smooth top range in 2007, and recently two of the five burners have stopped working. Can someone tell me if it is the motherboard or the actual burners? Also, is there a way to run a self diagnostic on the range to determine the issue?
Jack
Ads By Google
Related Models
Maytag LRSC20A Ref - Sxs
Maytag LRSD20A Ref - Sxs
Maytag LRSD22A Ref - Sxs
Maytag LRSD24A Ref - Sxs
Maytag LRSW22A Ref - SXS/I&W
Maytag LRSW24A Ref - SXS/I&W
Maytag LRTC15A Ref - Top Mount
Maytag LRTC17A Ref - Top Mount
Maytag LRTC19A Ref - Top Mount
Maytag LRTD17A Ref - Top Mount
Maytag LRTD19A Ref - Top Mount
Maytag LRTD21A Ref - Top Mount
Maytag LRTD23A Ref - Top Mount
Maytag LRTS17A Ref - Top Mount
Maytag LRTS19A Ref - Top Mount
Maytag LRTW22A Ref - Top Mount/ I&W
  #2 (permalink)
Old 11-07-2011, 05:43 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for LRE30451ST models | AppliancePartsPros.com
Here is a manual which may help.
LRE30451 LG Electric Range Repair Service Manual - ApplianceDigest.com
You have to join the site to download the manual but it is free and this is a very good site for manuals and other info for the appliance repair DIYer.
If both elements went out at the same time I doubt it is the elements themselves. It would be too big of a coincidence.
Try unplugging the unit for a couple minutes to see if it will reset.
Check the wiring to the burners to see if they use a common power wire/line. Perhaps it is a bad connection or wire.
Try disconnecting the element user interface (keypad) and reconnecting it.
They do not give much info on the stove top keypad but it does show 2 cable sets coming off of it. Perhaps they control different element sets so it could be that board.
This is a complicated piece of equipment so unless you can find something fairly easily or have electronics experience it may be worth getting in a pro. I would try to make sure if you do get a pro that they have worked on this or a similar (as complicated) unit.
__________________
  #3 (permalink)
Old 11-11-2011, 11:45 AM
Junior Member
Default
Thanks Denman, I'll follow your recommendations.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Smooth top burners are not getting on Kaila Oven Repair (including Ranges and Cooktops) 0 08-02-2011 08:48 AM
Smooth top range burners are not working Kaila Oven Repair (including Ranges and Cooktops) 0 08-02-2011 08:32 AM
Jenn-Air smooth top stove quit working - tripped the breaker clu1945 Oven Repair (including Ranges and Cooktops) 0 03-15-2010 09:32 PM
LF burner of Whirlpool smooth top range not working badger.packer.fan Oven Repair (including Ranges and Cooktops) 0 12-09-2009 08:28 PM
One Element in Smooth Cooktop not working properly kklkkr Oven Repair (including Ranges and Cooktops) 0 07-16-2008 10:59 AM
