Discuss
microwave carousel motor not working
 in
Microwave Repair
It seems that my microwave carousel motor has some wires loose. sometimes the turnable works and some times it does
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » microwave carousel motor not working
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 12-11-2007, 05:27 PM
nancy11 nancy11 is offline
Junior Member
nancy11 is on a distinguished road
Default microwave carousel motor not working
Model Number: MH1150XMB-4   Brand: Whirlpool   Age: 1 - 5 years
sometimes the turnable works and some times it does not work. some times it works after 40 seconds or so. I have cleaned the area properly but it is still not working. I am pretty sure the area is cleaned. I tried cleaning it several times. It looks like there is some loose contact in the motor.
How can I repair this?
Please guide me.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-11-2007, 07:39 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The first thing I would check is the turntable support (#7 on the turntable parts break down diagram). It could be worn out or cracked.
- The part number for the support AP3882860
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 12-12-2007, 02:33 PM
Junior Member
Default
Part no.7 seems looks ok. I tried turn it and it works fine.
Anything underneath that might be broken?
  #4 (permalink)
Old 12-12-2007, 03:25 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Did you remove the part to check it from the bottom?
__________________
  #5 (permalink)
Old 01-20-2008, 05:45 PM
Junior Member
Default
Yes, I checked the part and it is good. No crack or rusting.
  #6 (permalink)
Old 01-22-2008, 02:47 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Remove the bottom panel.
Make sure the turn table switch is "on".
Remove the electrical plug from the turn table motor and check for 120V coming to the motor when the microwave is "on".
Post the result, please.
__________________
  #7 (permalink)
Old 06-19-2008, 09:34 PM
Junior Member
Default Started working but on and off....
Finally, I got time to open the bottom panel and checked the volt. Some times it was 120 and some times it was not coming at all. I mean 0 volt.
I opened the keypad panel and tighten all cables. It started working. But it was for few days only. It has again started behaving weird.
It is a loose contact. If I tap the microwave panel from the side, it works.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Buying the right microwave turntable motor rcollison Microwave Repair 2 02-01-2008 04:42 AM
Wax motor not working bcanapp Washer Repair 1 12-09-2007 08:08 PM
Dryer Motor Not Working starr Dryer Repair 3 10-20-2007 04:52 PM
Carousel in Microwave Not Working billronald Microwave Repair 1 09-05-2007 02:20 PM
Motor not working properly W. Henderson Washer Repair 0 08-14-2007 06:06 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
