Discuss
Danby the beeping microwave
 in
Microwave Repair
I have one of those black Danby DMW### something microwaves, and it will work for a short while before it
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Danby the beeping microwave
  #1 (permalink)
Old 10-25-2011, 04:26 PM
Junior Member
draven66 is on a distinguished road
Default Danby the beeping microwave
Brand: -brand-   Age: Less than 1 year
I have one of those black Danby DMW### something microwaves, and it will work for a short while before it starts beeping then the controls stop working. It does this almost immediatly when it is hot or around alot of humidity but behaves better in the winter. I read somewhere I should replace the HV cap or the draining diode. I tested the diode with an ohmeter and it doesn't give me a reading.
I'd really like to fix this on my own despite whatever cost so I can learn from the experience. The knowledge is more important to me then buying a new one and filling up the landfill.
  #2 (permalink)
Old 10-26-2011, 07:33 PM
Junior Member
Default no replies?!
ok well I replaced the drain diode on the hv cap and the problem is still apparent after a few minutes of use so my educated guess is that it's the control board for the touchpad thats sending bogus signals till it locks up since the microwave heats up a dish fine until that happens.
Can someone confirm my suspicion? I don't see anything suspicious on the control board after a glance. No bulging caps.
  #3 (permalink)
Old 09-10-2017, 02:26 AM
Junior Member
mpablate is on a distinguished road
Default
I think it is a minor problem, have you tried resetting?
I mean unplug the oven, and open the door of the oven, and press 0 and reset button together while plugin the oven back in.
If this doesn't work, I think you need to call a technician as well.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Beeping thermador double microwave oven Nabeel Syed Oven Repair (including Ranges and Cooktops) 10 06-01-2015 01:52 PM
Spacemaker XL Microwave has continuous beeping Holly Mck Microwave Repair 0 06-12-2010 12:19 PM
Beeping microwave papajohn7 Microwave Repair 0 04-30-2010 07:13 PM
microwave beeping and now locked jhedeman Microwave Repair 1 03-09-2009 07:00 PM
microwave beeping LCD screen blank momo19680 Microwave Repair 1 08-22-2008 11:55 AM
