I have just ordered part AP2805459 which is a plastic latch attached to the dryer door and connects to the main dryer unit when the door is closed. I am not sure how to take out the broken latch and replace it with the new one. The door does not have apparent or visible access points to this latch. Any ideas? Thank you.:confused:
