Discuss
No Power
 in
Microwave Repair
The microwave has no power to the control panel. Checked breaker box, it's ok. The interior light DOES work.
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » No Power
  #1 (permalink)
Old 12-05-2007, 05:08 PM
SteveM SteveM is offline
Junior Member
SteveM is on a distinguished road
Default No Power
Model Number: MH6110XEB0   Brand: Whirlpool   Age: Less than 1 year
The microwave has no power to the control panel. Checked breaker box, it's ok. The interior light DOES work. The work light, fan and control panel are dead. I found the parts lists and simple diagrams but my problem is that I don't know how to get to the FUSE inside the unit. The diagram looks like the FUSE is behind the control panel on the right side of the unit. I need help removing the panels to access the FUSE. Thanks.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-05-2007, 06:44 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
If the interior light does work then there is nothing wrong with the fuse.
Most likely the problem is a bad control board.
In order to get access to the parts behind the control panel you have to remove two screws holding the top panel (aka vent grill) first and pull the top panel toward yourself.
Remove the screw on top of the control panel, slide it up to release from the tabs and pull it out.
- The part number for the control board AP3119663
- Here are the break down diagrams for the Whirlpool microwave Model MH6110XEB0
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dishwasher has no power SLHagberg Dishwasher Repair 0 11-24-2007 08:53 AM
Roper Won't power up cmedics Dishwasher Repair 1 11-14-2007 10:18 PM
No power light sjdipple Dishwasher Repair 0 11-06-2007 02:27 PM
No Power. dogfuzzn Washer Repair 2 10-11-2007 04:52 AM
No Power? dangdryer Dryer Repair 0 09-05-2007 05:17 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
