rcsch5056
#1 Posted : Tuesday, September 27, 2011 12:01:00 PM(UTC)
rcsch5056
Please I need help!
Just replaced the -PCB- (Printed curcuit board)# 6871W1S128C.
There are 4 wire plugs to connect to the board. 3 of which are murphy proof connections so no problems there. The last is a 2 spade female connector for RY2. Problem is I didn't mark it when seperated it from the board. The female plug, to plug onto the board, has one side with a black & a yellow wire - the other has a black & a red wire.
what is the correct orientation of the female plug to the RY2.
I am looking at the connection side of the PCB with the RY2 in the lower right corner.
Thanks for the help
rcsch5056 attached the following image(s):
