Discuss
Microwave oven - no LCD, even clock, light bulb inside door worked
 in
Microwave Repair
Hi tech support, would you please help. None of the button on the control panel of my microwave oven worked,
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Microwave oven - no LCD, even clock, light bulb inside door worked
  #1 (permalink)
Old 04-14-2009, 06:37 PM
thuythu thuythu is offline
Junior Member
thuythu is on a distinguished road
Question Microwave oven - no LCD, even clock, light bulb inside door worked
Model Number: MMV5000BDW   Brand: Maytag   Age: 5 - 10 years
Hi tech support, would you please help. None of the button on the control panel of my microwave oven worked, even clock, nothing work, all quiet. However, when the door is opened, the light bulb still turned on. I saw a forum which described the same symptom and the suggestion of changing a fuse, but after that, i do not see any feedback. anyway, would you please advise whether a fuse needs to be replaced in my case also and if so, then how can i get access to the fuse, so that i can change? also, would you please tell me what is the part number to buy. thank you very much in advance. Regards, Thu.
Related Models
Maytag MMV5000BDW Mwave - Mounted Under Cabinet
Maytag MMV5100AAB Mwave - Mounted Under Cabinet
Maytag MMV5100AAQ Mwave - Mounted Under Cabinet
Maytag MMV5100AAS Mwave - Mounted Under Cabinet
Maytag MMV5100AAW Mwave - Mounted Under Cabinet
Maytag MMV5156AAB Mwave - Mounted Under Cabinet
Maytag MMV5156AAQ Mwave - Mounted Under Cabinet
Maytag MMV5156AAS White Westinghouse/refrigerator
Maytag MMV5156AAW Mwave - Mounted Under Cabinet
Maytag MMV5156ACB Mwave - Mounted Under Cabinet
Maytag MMV5156ACQ Mwave - Mounted Under Cabinet
Maytag MMV5156ACS Mwave - Mounted Under Cabinet
Maytag MMV5156ACW Mwave - Mounted Under Cabinet
Maytag MMV5165AAB Mwave - Mounted Over Range/wo
Maytag MMV5165AAQ Mwave - Mounted Over Range/wo
Maytag MMV5165AAS Mwave - Mounted Over Range/wo
Maytag MMV5165AAW Mwave - Mounted Over Range/wo
Maytag MMV5165BAB Mwave - Mounted Over Range/wo
Maytag MMV5165BAQ Mwave - Mounted Over Range/wo
Maytag MMV5165BAS Mwave - Mounted Over Range/wo
Maytag MMV5165BAW Mwave - Mounted Over Range/wo
Maytag MMV5186AAB Mwave - Mounted Under Cabinet
Maytag MMV5186AAQ Mwave - Mounted Under Cabinet
Maytag MMV5186AAS Mwave - Mounted Under Cabinet
Maytag MMV5186AAW Mwave - Mounted Under Cabinet
Maytag MMV5186ACB Mwave - Mounted Under Cabinet
Maytag MMV5186ACQ Mwave - Mounted Under Cabinet
Maytag MMV5186ACS Mwave - Mounted Under Cabinet
Maytag MMV5186ACW Mwave - Mounted Under Cabinet
Maytag MMV5207AAB Mwave - Mounted Over Range/wo
Maytag MMV5207AAQ Mwave - Mounted Over Range/wo
Maytag MMV5207AAS Mwave - Mounted Over Range/wo
Maytag MMV5207AAW Mwave - Mounted Over Range/wo
Maytag MMV5207ACB Mwave - Mounted Over Range/wo
Maytag MMV5207ACQ Mwave - Mounted Over Range/wo
Maytag MMV5207ACS Mwave - Mounted Over Range/wo
Maytag MMV5207ACW Mwave - Mounted Over Range/wo
Maytag MMV5207BAB Mwave - Mounted Over Range/wo
Maytag MMV5207BAQ Mwave - Mounted Over Range/wo
Maytag MMV5207BAS Mwave - Mounted Over Range/wo
Maytag MMV5207BAW Mwave - Mounted Over Range/wo
Maytag MMV5207BCB Mwave - Mounted Over Range/wo
Maytag MMV5207BCQ Mwave - Mounted Over Range/wo
Maytag MMV5207BCS Mwave - Mounted Over Range/wo
Maytag MMV5207BCW Mwave - Mounted Over Range/wo
Maytag MMV6178AAB Microwave - Convection
Maytag MMV6178AAQ Microwave - Convection
Maytag MMV6178AAS Microwave - Convection
Maytag MMV6178AAW Microwave - Convection
Maytag MMW5527BAB Walloven - S/c Ele
Maytag MMW5527BAW Walloven - S/c Ele
Maytag MMW5527CAB Walloven - S/c Ele
Maytag MMW5527CAW Walloven - S/c Ele
Maytag MMW5530BAB Walloven - S/c Ele
Maytag MMW5530BAW Walloven - S/c Ele
Maytag MMW5530CAB Walloven - S/c Ele
Maytag MMW5530CAW Walloven - S/c Ele
Maytag MMW5530DAB Walloven - S/c Mwave Ele
Maytag MMW5530DAW Walloven - S/c Mwave Ele
Norge MN15E-5 Mwave - Cntrtp / Stand Alone
Norge MN15F-14T Mwave - Cntrtp / Stand Alone
Norge MN15FN-14T Mwave - Cntrtp / Stand Alone
Norge MN46G-14T Mwave - Cntrtp / Stand Alone
Norge MN46GN-14T Mwave - Cntrtp / Stand Alone
Maytag MO1450BA Mwave - Mounted Over Range/wo
Maytag MO1450CA Mwave - Mounted Over Range/wo
Maytag MO1450WA Mwave - Mounted Over Range/wo
Maytag MO1650BA Mwave - Mounted Over Range/wo
Maytag MO1650CA Mwave - Mounted Over Range/wo
Maytag MO1650WA Mwave - Mounted Over Range/wo
Magic Chef MOD61AD Mwave - Mounted Over Range/wo
Magic Chef MOD61WH Mwave - Mounted Over Range/wo
Magic Chef MOD62AD Mwave - Mounted Over Range/wo
Magic Chef MOD62WH Mwave - Mounted Over Range/wo
Magic Chef MOD62WOW Mwave - Mounted Over Range/wo
Magic Chef MOD64WOW Mwave - Mounted Over Range/wo
Magic Chef MOD65B Mwave - Mounted Over Range/wo
Magic Chef MOD65WOW Mwave - Mounted Over Range/wo
Whirlpool MODEL_PBK0190
Whirlpool MODEL_PBK0191
Whirlpool MODEL_PBK0838
Magic Chef MODW1A Mwave - Mounted Over Range/wo
Magic Chef MODW1V Mwave - Mounted Over Range/wo
Amana MP1.A Commercial Microwaves
Amana MP1.B Commercial Microwaves
Amana MPD218-02 Mwave - Family Size (60 Hz)
Amana MPD219-02 Mwave - Family Size (60 Hz)
Frigidaire MPF200PBDA Frg(v2) / Gas Range
Frigidaire MPF200PBWA Frg(v1) / Gas Range
Frigidaire MPF300BPDA Gib(v9) / Gas Range
Frigidaire MPF300PBDA Frg(v1) / Gas Range
Frigidaire MPF300PBDB Wwh(v1) / Gas Range
Frigidaire MPF300PBDC Frg(v1) / Gas Range
Frigidaire MPF300PBDD Frg(v1) / Gas Range
Frigidaire MPF300PBDE Frg(v1) / Gas Range
Frigidaire MPF300PBDF Frg(v1) / Gas Range
Frigidaire MPF300PBWA Frg(v2) / Gas Range
Frigidaire MPF300PBWB Wwh(v2) / Gas Range
Frigidaire MPF300PBWC Frg(v2) / Gas Range
Frigidaire MPF300PBWD Frg(v2) / Gas Range
Frigidaire MPF300PBWE Frg(v2) / Gas Range
Frigidaire MPF300PBWF Frg(v2) / Gas Range
Frigidaire MPF300PXWA Frg(v0) / Gas Range
Frigidaire MPF300PXWB Frg(v3) / Gas Range
Frigidaire MPF300PXWC Frg(v0) / Gas Range
Uni MPF300PXWG Universal/gas Range
Uni MPF300PXWH Universal/gas Range
Uni MPF300PXWJ Universal/gas Range
Frigidaire MPF303PGDA Frg(v3) / Gas Range
Frigidaire MPF303PGDD Frg(v5) / Gas Range
Uni MPF303PGDF Universal/gas Range
Uni MPF303PGDG Universal/gas Range
Uni MPF303PGDH Universal/gas Range
Frigidaire MPF303PGWA Frg(v4) / Gas Range
Frigidaire MPF303PGWC Frg(v6) / Gas Range
Frigidaire MPF303PGWD Frg(v7) / Gas Range
Uni MPF303PGWF Universal/gas Range
Uni MPF303PGWG Universal/gas Range
Uni MPF303PGWH Universal/gas Range
Frigidaire MPF311PCDA Tap(v1) / Gas Range
  #2 (permalink)
Old 04-15-2009, 03:31 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
Thu,
Remove the top grille and open the control panel. Check for continuity the magnetron thermal cut-off (#14 on the diagram). If this part is not accessible through the control panel opening then you have to remove the microwave from the cabinet.
If the thermal cut-off is open then it has to be replaced and you have to make sure the cooling fan is working.
If the thermal cut-off is good then the problem is a bad control board.
- The part number for the thermal cut-off is AP4060517
- The part number for the control board is AP4062549
Here are the breakdown diagrams and Replacement parts for MAYTAG MMV5000BDW | AppliancePartsPros.com
__________________
  #3 (permalink)
Old 04-16-2009, 11:53 AM
Junior Member
Question thermal cut-off open?
Thank you Gene. I will try to open. However, would you please tell me how do I know the thermal cut-off open? Is there a switch in this part, would you please give me a hint? So, what you are saying is not a fuse's problem? What symptom would it be a fuse's problem? I am learning to fix things myself. Thank you very much again for your help. Regards, Thu.
  #4 (permalink)
Old 04-16-2009, 03:43 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by thuythu View Post
...would you please tell me how do I know the thermal cut-off open?...
...So, what you are saying is not a fuse's problem? What symptom would it be a fuse's problem?...
Thu,
You have to check it for continuity. The following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter - How To Check Continuity With Ohmmeter
No, this is not a fuse problem. I mean this is not an IN-LINE fuse problem because the thermal cut-off is kind of fuse too. The only difference - this a THERMAL fuse which works by the temperature while the in-line fuse works by the current. In case if an in-line fuse blows the microwave is going to be completely dead - no noise, no lights, no display. Nothing.
__________________
  #5 (permalink)
Old 04-16-2009, 04:59 PM
Junior Member
Default thermal cut-off
Hi Gene, thank you for your help again.
I will follow your instructions and will give a try . Hope it is only the thermal cut-off problem. If it is the whole control panel, then no luck! It is not worth to replace the control panel, since I looked at the price, it is too expensive. In this case, it is cheaper to buy a new microwave oven. Regards, Thu Tran.
  #6 (permalink)
Old 04-16-2009, 08:53 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
__________________
  #7 (permalink)
Old 04-24-2009, 09:25 PM
Junior Member
Default microwave oven - no LCD, even clock, light bulb inside door worked
Hi Gene, today, I opened the control panel side, however, I could not locate the TCO as it was shown in the little picture (#14). I looked over and over again, the only mentioned TCO is on a yellow wire which connected to a 6 wire plugs on the control board, the yellow wire labeled (yellow) TCO H.D, then there are other 5 wires on the same plug which said like (red) COM MGT, (black) Geared Motor etc ... the other end of these 6 wires were connected to a rectangular blue plastic part with one blank button, this button seems to operate the open and close door and turn on and turn off the light inside the microwave. Other than that, I do not know where is the TCO part that you mentioned about. Would you please direct. Would you please tell me where the defected part near by? Is this right on the control panel or inside the cavity where it looks like the magnetron (#1) is located? Thank you very much for your clarification. Regards, Thu.
  #8 (permalink)
Old 04-25-2009, 08:33 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Thu,
It looks like a small tablet
and it is attached to the magnetron
__________________
  #9 (permalink)
Old 04-26-2009, 10:54 AM
Junior Member
Hi Gene, thank you very much again. I could not locate this part on the control panel, the magnetron looks big, it seems to me that it is inside the cavity behind the control panel. Am I right? I looked at the image of the TCO that you sent, it does not look like any attachment to the picture on the magnetron, so, it might be behind the magnetron that I do not see, am I right? For the TCO, it saw the 2 prongs, are these the ones that I need to put the meter to test for the open and close that you talked about previously? If my assumption is correct as above, then I would like to ask you how do I bring down the microwave oven from the cabinet? I could not see how was it hung? Please give me tips. Thank you very much again. Thank you for your patience to the novice. Regards, Thu.
  #10 (permalink)
Old 04-26-2009, 12:36 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
...1. it might be behind the magnetron that I do not see...
...2. For the TCO, it saw the 2 prongs, are these the ones that I need to put the meter to test for the open and close that you talked about previously?...
...3. how do I bring down the microwave oven from the cabinet?...
Thu,
1. Very likely it is there.
2. The answer is - Yes.
3. You can find the complete instructions in the Installation manual.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Microwave interior light bulb replacement Ardith Microwave Repair 5 10-02-2009 08:23 PM
Microwave light bulb replacement, Whirlpool Flyingace507@Maytag.com Microwave Repair 1 01-28-2009 08:27 PM
Microwave replacement Light bulb underneath light sieglesx4 Microwave Repair 0 12-27-2008 08:52 AM
Microwave light bulb replacement Sant Microwave Repair 3 08-31-2008 09:48 AM
2006 kenmore microwave light bulb needs replacing rogerskoler Microwave Repair 2 03-31-2008 02:32 PM
