i am able to get insert away from inside of door and unscrew the top and bottom screw for door handle. the bottom of my handle broke off and the bottom piece of l plastic is still in front of door, top part of handle is fine. the problem is there seems to be another top and bottom screw in handle hidden by the mental frame under the insert, how do you get that off to unscrew the other screws i didn't want to pull on the handle and break off the top also. the instructions indicated only two screws top and bottom this doesn't appear correct, can you make this a little clear, for now i put everthing back as it was. tanya:(
