Recently purchased a home with this Bosch microwave. The previous owners must have had the burners set on high to heat the home because the underside of the over-the-range microwave door and the range hood light cover are partially melted. I'd like to replace the door, or at least the plastic part of it that has melted, but I do not know where to start to remove the door.
