Just installed a brand new GE Over the Range Profile (Spacemaker) Microwave PVM2070SMSS and can't tell whether the external vent is working properly. The unit is meant to vent externally, outside top exhaust. Is there a way to test whether the vent is working as intended? It seems to put out a lot of air from the top of the unit, but I cant tell whether this is normal or not. Should it be pulling air from the BOTTOM of the unit? The instruction manual gives no detailed information as to how I can determine whether the unit is operating properly. Please help! Thank you!
