I have a microwave from 1985 that works great. Unfortunately, the door opening mechanism broke. I have taken the door off. I think the rod that goes from the bottom hinge up to the latch is broken. The rod is only 3 inches long. Did the rod break or is it a part that attaches to the latch? Any ideas on how to replace the rod (since the part is not available any longer)? Thanks! Big K Big K in PDX attached the following image(s):
