Discuss
Lights wont lite up after being replaced
 in
Microwave Repair
I have a whirlpool mh7130xeb-2, The lights on the back blew out and one of the bulbs shattered, I
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Lights wont lite up after being replaced
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 11-21-2007, 07:38 AM
abovepc abovepc is offline
Junior Member
abovepc is on a distinguished road
Cool Lights wont lite up after being replaced
Model Number: mh7130xeb   Brand: Whirlpool   Age: 5 - 10 years
I have a whirlpool mh7130xeb-2, The lights on the back blew out and one of the bulbs shattered, I replaced both bulbs and nothing happens, there isnt even a beep when I press the light button. Can someone help me trouble shoot and get this working with out costing me 100's of dollars?
Thanks,
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-24-2007, 06:27 PM
jlwbassman jlwbassman is offline
Junior Member
jlwbassman is on a distinguished road
Default GE microwave Light problem
I am having as similar problem... A light blew out and after replacing the bulb it won't work....
Have you come up with any answers.
JW
  #3 (permalink)
Old 11-25-2007, 04:12 AM
Junior Member
Red face Still Nothing
Sorry still havent received any answers for the light bulb problem. I could use a location for the manual too if anyone has that maybe it would help.
  #4 (permalink)
Old 11-25-2007, 05:57 AM
jumptrout51 jumptrout51 is offline
Expert
APP Volunteer
jumptrout51 is on a distinguished road
Default
Check your fuse.
  #5 (permalink)
Old 11-25-2007, 08:12 AM
Junior Member
Default
I changed the 15 amp fuse... Still does not work...
  #6 (permalink)
Old 11-25-2007, 02:50 PM
Junior Member
Talking Where is it?
If I knew were the fuse was I could check it. Does anyone have a manual? or could you tell me where the fuse is?
  #7 (permalink)
Old 01-25-2008, 08:21 AM
rgl rgl is offline
Junior Member
rgl is on a distinguished road
Default
I thought both lights had burned out on mine but new ones did not light up. It turned out to be the solenoid on the circuit board. It was going to cost something like $150 for a new board so I just hard wired in a 120v toggle switch and spliced into a hot wire from the power supply. The touch pad button no longer does anything and there is only one light level, not bright and dim as before.
The fuse is an inline type and is easy to find. There is a schematic sheet tucked inside the unit that you will find when opened. I found the upper vent bezel the trickiest to remove, I think there were two screws and then it had to be popped out of some snap connectors but it was a while ago and I could be wrong. Just be careful and you wont break anything.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven won't lite? Chris7525 Oven Repair (including Ranges and Cooktops) 6 11-12-2007 06:14 AM
ballas lite above burners wont come on thehawkfish Oven Repair (including Ranges and Cooktops) 0 10-27-2007 02:44 PM
Maytag Gas Range Oven wont lite Rick2462 Oven Repair (including Ranges and Cooktops) 1 10-10-2007 10:30 AM
Wont start/start switch replaced awilliams197 Dryer Repair 1 09-18-2007 01:33 AM
Cooktop lite Stu Mills Microwave Repair 0 08-24-2007 11:23 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
