Discuss
GE Profile Microwave not heating
 in
Microwave Repair
I have a GE Profile Microwave/Oven Combo. The Model Number is JTP85WOA5WW Serial # HA670514Q Manufactured May 2001 The microwave
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » GE Profile Microwave not heating
  #1 (permalink)
Old 07-15-2011, 08:21 AM
Junior Member
jniggli is on a distinguished road
Default GE Profile Microwave not heating
Model Number: JTP85WOA5WW   Brand: GE   Age: More than 10 years
Serial # HA670514Q
The microwave portion has a problem. The lights work, clock works, everything from the control panel seems fine. When I try to cook something, the lights, turntable and everything are functioning. The unit gives off an hot electrical odor and nothing gets cooked. It also seems to be humming slightly louder than when it was in working order. I removed the capacitor and diode. The capacitor reads a perfect 950nf that matches the .95uf on the label. I checked the diode with a transistor battery. I put one leg of the diode on the battery and put my voltage meter on the other leg and back to the other terminal of the battery. I got 9 VDC checking one way, reversed the diode and got 0 VDC the other way, so the diode looks good. I tried to check the windings of the HV Transformer. The input side (measuring resistance across black and white has continuity and checking to ground it had 4.25K Ohms. The output side across the Magnetron showed continuity and had no continuity to ground. There was another wire that went from the transformer right to the capacitor (by itself) and it measured 80 Ohms to ground.
Then I measured the magnetron terminals with the harness disconnected. I get 37 ohms to ground on each terminal. This puzzles me. I would think they should be open. Does anyone know if the transformer readings look right? What should the Magnetron read? I know how to get measurements but don't know what readings indicate failure for sure. Any idea? HELP!
Related Models
General Electric JTP85WW1WW Electric range
General Electric JTP85WW2WW Electric range
General Electric JTP86BF1BB Electric range
General Electric JTP86BF2BB Electric range
General Electric JTP86BF3BB Electric range
General Electric JTP86BF4BB Electric range
General Electric JTP86BF5BB Electric range
General Electric JTP86BF6BB Electric range
General Electric JTP86BF7BB Electric range
General Electric JTP86CF1CC Electric range
General Electric JTP86CF2CC Electric range
General Electric JTP86CF3CC Electric range
General Electric JTP86CF4CC Electric range
General Electric JTP86CF5CC Electric range
General Electric JTP86CF6CC Electric range
General Electric JTP86CF7CC Electric range
General Electric JTP86SF1SS Electric range
General Electric JTP86SF2SS Electric range
General Electric JTP86SF3SS Electric range
General Electric JTP86SH1SS Electric range
General Electric JTP86SH2SS Electric range
General Electric JTP86SH3SS Electric range
General Electric JTP86SH4SS Electric range
General Electric JTP86SH5SS Electric range
General Electric JTP86SH6SS Electric range
General Electric JTP86WF1WW Electric range
General Electric JTP86WF2WW Electric range
General Electric JTP86WF3WW Electric range
General Electric JTP86WF4WW Electric range
General Electric JTP86WF5WW Electric range
General Electric JTP86WF6WW Electric range
General Electric JTP86WF7WW Electric range
General Electric JTP90BM1BB BUILT IN OVEN W/MICROWAVE
General Electric JTP90BM2BB BUILT IN OVEN W/MICROWAVE
General Electric JTP90CM1CC BUILT IN OVEN W/MICROWAVE
General Electric JTP90CM2CC BUILT IN OVEN W/MICROWAVE
General Electric JTP90DP1BB BUILT IN OVEN W/MICROWAVE
General Electric JTP90DP1CC BUILT IN OVEN W/MICROWAVE
General Electric JTP90DP1WW BUILT IN OVEN W/MICROWAVE
General Electric JTP90DP2BB BUILT IN OVEN W/MICROWAVE
General Electric JTP90DP2CC BUILT IN OVEN W/MICROWAVE
General Electric JTP90DP2WW BUILT IN OVEN W/MICROWAVE
General Electric JTP90DP3WW BUILT IN OVEN W/MICROWAVE
General Electric JTP90SM1SS BUILT IN OVEN W/MICROWAVE
General Electric JTP90SM2SS BUILT IN OVEN W/MICROWAVE
General Electric JTP90SP1SS BUILT IN OVEN W/MICROWAVE
General Electric JTP90SP2SS BUILT IN OVEN W/MICROWAVE
General Electric JTP90WM1WW BUILT IN OVEN W/MICROWAVE
General Electric JTP90WM2WW BUILT IN OVEN W/MICROWAVE
General Electric JTP95BA1BB Electric range
General Electric JTP95BA2BB Electric range
General Electric JTP95BA3BB Electric range
General Electric JTP95BA4BB Electric range
General Electric JTP95BA5BB Electric range
General Electric JTP95BA6BB Electric range
General Electric JTP95BD1BB Electric range
General Electric JTP95BW1BB Electric range
General Electric JTP95BW2BB Electric range
General Electric JTP95WA1WW Electric range
General Electric JTP95WA2WW Electric range
General Electric JTP95WA3WW Electric range
General Electric JTP95WA4WW Electric range
General Electric JTP95WA5WW Electric range
General Electric JTP95WA6WW Electric range
General Electric JTP95WD1WW Electric range
General Electric JTP95WW1WW Electric range
General Electric JTP95WW2WW Electric range
 JTRH2 COMMERCIAL COOKING
Maytag JTRH2 JADE/COMMERCIAL COOKING (COOKING GAS)
 JTRH2A COMMERCIAL COOKING
Maytag JTRH2A JADE/COMMERCIAL COOKING (COOKING GAS)
Maytag JTRH2FHT36 JADE TITAN RANGE (COOKING GAS)
Maytag JTRH36GT36C JADE TITAN GRIDDLE (COOKING GAS)
Maytag JTRH3ST36 JADE COOKING (COOKING GAS)
Maytag JTRH430 JADE COOKING (COOKING GAS)
Maytag JTRH436 JADE COOKING (COOKING GAS)
Maytag JTRH636 JADE COOKING (COOKING GAS)
Maytag JTRH636C JADE COOKING (COOKING GAS)
 JTRHE4336C COMMERCIAL COOKING
 JTRMB36 COMMERCIAL COOKING
Maytag JTRMB36 JADE/COMMERCIAL COOKING (COOKING GAS)
General Electric JTS10DP1BB ELECTRIC OVEN
General Electric JTS10SP1SS ELECTRIC OVEN
Maytag JUB248LBCX00 BEVERAGE CENTER
Maytag JUB248LBCX01 BEVERAGE CENTER
Maytag JUB248LBCX02 BEVERAGE CENTER
Maytag JUB248LBRB00 BEVERAGE CENTER
Maytag JUB248LBRB01 BEVERAGE CENTER
Maytag JUB248LBRS00 BEVERAGE CENTER
Maytag JUB248LBRS01 BEVERAGE CENTER
Maytag JUB248LWRS00 BEVERAGE CENTER
Maytag JUB248RBCX00 BEVERAGE CENTER
Maytag JUB248RBCX01 BEVERAGE CENTER
Maytag JUB248RBCX02 BEVERAGE CENTER
Maytag JUB248RBRB00 BEVERAGE CENTER
Maytag JUB248RBRB01 BEVERAGE CENTER
Maytag JUB248RBRS00 BEVERAGE CENTER
Maytag JUB248RBRS01 BEVERAGE CENTER
Maytag JUB248RWRS00 BEVERAGE CENTER
Jenn-Air JUC2450ACX WINE CELLAR / UNDER COUNTER REF
Jenn-Air JUC2450ARB WINE CELLAR / UNDER COUNTER REF
Jenn-Air JUC2450ARS WINE CELLAR / UNDER COUNTER REF
Jenn-Air JUC2450ARW WINE CELLAR / UNDER COUNTER REF
Maytag JUD248CCCX00 DOUBLE DRAWER
Maytag JUD248CCRS00 DOUBLE DRAWER
Maytag JUD248CWRS00 DOUBLE DRAWER
Jenn-Air JUD248CWRS01 DOUBLE DRAWER
Maytag JUD248RCCX00 DOUBLE DRAWER
Maytag JUD248RCRS00 DOUBLE DRAWER
Maytag JUD248RWRS00 DOUBLE DRAWER
Maytag JUD278DBCX00 INGREDIENT CENTER
Maytag JUD278DBES00 INGREDIENT CENTER
Maytag JUR248LBCX00 REFRIGERATOR
Maytag JUR248LBCX01 REFRIGERATOR
Jenn-Air JUR248LBCX02 REFRIGERATOR
Maytag JUR248LBEB00 REFRIGERATOR
Maytag JUR248LBES00 REFRIGERATOR
Maytag JUR248LWES00 RADIANT ELEMENT CARTRIDGE
Jenn-Air JUR248LWES01 REFRIGERATOR
Jenn-Air JUR248LYEP00 REFRIGERATOR
  #2 (permalink)
Old 07-22-2011, 06:31 AM
Junior Member
Stackdaddy is on a distinguished road
Default Same Symptoms for my GE Cabinet Mount Model JVM2070SH001
I have the same symptoms you describe form my GE Cabinet Mount Model JVM2070SH001. I have not taken any volt / ohm / continuity measurements though.
Did anyone ever provide additional information as to what the problem might be? Mine is still not working and I would like to diagnose the problem also.
Stack-D
  #3 (permalink)
Old 07-28-2011, 07:19 AM
Junior Member
Default
I went to a parts store and they let me test some magnatrons there with my ohmeter. All of the new ones I checked showed open from the contacts to the case. Mine was showing 37 ohms. They happened to have a replacement for the one I had so I took it and installed it. Everything now works fine.
  #4 (permalink)
Old 07-31-2011, 06:15 PM
Junior Member
Talking Magnatron & Diode Replaced - Problem Fixed
I checked my warranty and sure enough, the Magnatron was in fact the only thing that had a warranty for 10 years. So called the 1-800 number and had them send me the magnetron unit free of charge, and I went ahead and ordered the diode also, just for safe measure.
Replaced both of these, (even though the diode seemed fine). Plugged the unit back in with all the covers off, and for some reason it would not work, or at least the turn table would not turn. So then was thinking it may be the power supply / transformer, as my old magnetron seemed to test good when checking the contacts to chassis ground. But once I put it all back together, covers in place and all screwed back together, ran it again and it worked. So replacing the magnatron (and diode as recommended) is what I replaced to fix my unit.
Thanks all, and AppliancePartsPros.com for all the good info and help for fixing my 2003 unit.
Cheers,
Stack-D
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Profile Microwave over the range not heating sairam Microwave Repair 0 05-15-2011 11:56 AM
GE Profile convection/microwave buzzing; not heating pat.tilson Microwave Repair 0 03-22-2010 01:50 PM
GE Profile MW heating some but not enough fixer70816 Microwave Repair 0 02-14-2010 10:48 PM
ge profile xl1800 not heating up csa21372 Microwave Repair 0 05-01-2009 10:54 PM
GE Profile Microwave not heating Planinka Microwave Repair 14 11-02-2008 04:51 PM
