I was replacing the control panel and in tagging the wires that connect the microwave to control panel, i dropped the control panel and the wires became disconnected before i was able to tag. There are 5 wires as follow:
1 black/red two connector wire 2. white with red hash/solid white two connector wire 3. white with red hash/solid white/white with red dots three connector wire 4. red/black/white three connector wire 5. white with red has/solid white/white with red dots with four connector wire
