GRAYSTE
#1 Posted : Sunday, March 15, 2009 8:26:58 AM(UTC)
GRAYSTE
This past week the interior light and the hood light blew out. Replaced both bulbs and the lights do not work. The wife said that there was a flash of light when the lights burned out. They both went out at the same time. Is there a board or a fuse that is bad? What would cause both bulbs to blow at the same time.
TechnicianBrian
#2 Posted : Sunday, March 15, 2009 6:14:14 PM(UTC)
TechnicianBrian
The control board () is the only common component to both those lamps (and everything else for that matter) as they share no wiring or connection points. I would try replacing the lamps with the power disconnected to the unit and see if the new ones last. The control board is an unlikely failure point if everything else is working. If the turntable motor, and vent fan (the other components tied with the lamps at the board) start having troubles, then I would look at the wiring from the interlock switches to the board itself for a loose connection.
GE Oven - Microwave/Oven PT7800SH2SSA (Oven Repair (including Ranges and Cooktops))
by Guest 2/13/2024 11:22:12 AM(UTC)
Kenmore Pizza Oven Microwave (Microwave Repair)
by mwjkmail 2/3/2024 5:10:49 PM(UTC)
Kitchenaid (Whirlpool) Microwave door switches (Microwave Repair)
by ForumUser1 1/11/2024 1:11:07 PM(UTC)
Whirlpool Microwave Lower Bulb will not turn on (WMH31017HS08) (Microwave Repair)
by Axtell 1/2/2024 3:49:44 PM(UTC)
Kitchen aid electric wall microwave and oven (Microwave Repair)
by Guest 11/9/2023 8:15:09 AM(UTC)
Frigidaire Microwave PLMVZ169HCA (Microwave Repair)
by Guest 10/25/2023 11:02:01 AM(UTC)
KitcheAid Microwave/Oven Wall Combo KOCE500ESS05 Error Code F6E8 (Microwave Repair)
by tjperlman 10/19/2023 10:07:59 PM(UTC)
Microwave Advantium 120 display blank (Microwave Repair)
by tod.colbert@gmail.com 8/6/2023 9:13:49 AM(UTC)
Litton model 1800 microwave (Microwave Repair)
by Guest 7/14/2023 7:08:12 PM(UTC)
Microwave touchpad (Microwave Repair)
by duguyisheng 7/6/2023 5:12:28 PM(UTC)
Over range Microwave exhaust fan slows (Microwave Repair)
by Mmetzinger 6/3/2023 7:19:23 AM(UTC)
Dim Light on Microwave (Microwave Repair)
by Guest 5/15/2023 8:31:44 AM(UTC)
Kitchenaid kbms1454bbl microwave (Microwave Repair)
by Guest 4/1/2023 10:24:42 AM(UTC)
Microwave Parts Cannot Be Returned and Microwave Still Has The Problem (Microwave Repair)
by atlantic 3/31/2023 12:42:43 PM(UTC)
Apollo convection microwave (Microwave Repair)
by Guest 2/21/2023 12:14:33 PM(UTC)
