Discuss
GE Advantium Microwave SCB1001KSS
 in
Microwave Repair
2 years old, new in Feb 2007, $1300 Combination Speedcook/Microwave Advantium, GE Profile, In Wall SCB1001KSS Thunderstorm last night and
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » GE Advantium Microwave SCB1001KSS
  #1 (permalink)
Old 03-12-2009, 07:43 PM
Junior Member
MK82Man is on a distinguished road
Thumbs down GE Advantium Microwave SCB1001KSS
Model Number: SCB1001KSS   Brand: GE   Age: 1 - 5 years
Thunderstorm last night and now the LED Display is out. I searched the forums for this model and didn't find anything. Have been unable to find a schematic blow-up or accurate part number. The lower part of the LED display works, small yellow print text "locked, oven, turn dial", and the Microwave works. You can press Express and the MW runs for 30 secs like it is supposed to and the small "oven" illuminates and your coffee warms up. Anyone have thoughts or suggestions? I've attached the Display PDF #11 (upper portion, LED). Is the LED unit fried? Is there a fuse protecting the display? A link for a step by step. I installed it and don't mind taking it out for a DIY repair. Thanks in advance.
Ads By Google
Related Models
General Electric SCB1001KSS01 Counter top microwave
General Electric SCB1001KSS02 Counter top microwave
General Electric SCB2000CAA03 Counter top microwave
General Electric SCB2000CBB03 Counter top microwave
General Electric SCB2000CCC03 Counter top microwave
General Electric SCB2000CWW03 Counter top microwave
General Electric SCB2000FBB01 Counter top microwave
General Electric SCB2000FBB02 Counter top microwave
General Electric SCB2000FBB03 Counter top microwave
General Electric SCB2000FCC01 Counter top microwave
General Electric SCB2000FCC02 Counter top microwave
General Electric SCB2000FCC03 Counter top microwave
General Electric SCB2000FWW01 Counter top microwave
General Electric SCB2000FWW02 Counter top microwave
General Electric SCB2000FWW03 Counter top microwave
General Electric SCB2001CSS03 Counter top microwave
General Electric SCB2001FSS01 Counter top microwave
General Electric SCB2001FSS02 Counter top microwave
General Electric SCB2001KSS01 Counter top microwave
General Electric SCB2001KSS02 Counter top microwave
General Electric SCBC2000CBB00 Counter top microwave
General Electric SCBC2000CBB001
General Electric SCBC2000CBB01 Counter top microwave
General Electric SCBC2000CCC00 Counter top microwave
General Electric SCBC2000CCC001
General Electric SCBC2000CCC01 Counter top microwave
General Electric SCBC2000CWW00 Counter top microwave
General Electric SCBC2000CWW001
General Electric SCBC2000CWW01 Counter top microwave
General Electric SCBC2001CSS00 Counter top microwave
General Electric SCBC2001CSS001
General Electric SCBC2001CSS01 Counter top microwave
Amana SCD19H Ref - SXS/I&W
Amana SCD19J Ref - SXS/I&W
Amana SCD22J Ref - SXS/I&W
Amana SCD22NL Ref - SXS/I&W
Amana SCD22NW Ref - SXS/I&W
Amana SCD22TBL Ref - SXS/I&W
Amana SCD22TBW Ref - SXS/I&W
Amana SCD23VBL Ref - SXS/I&W
Amana SCD23VBW Ref - SXS/I&W
Amana SCD23VL Ref - SXS/I&W
Amana SCD23VW Ref - SXS/I&W
Amana SCD25J Ref - SXS/I&W
Amana SCD25JB Ref - SXS/I&W
Amana SCD25JP Ref - SXS/I&W
Amana SCD25N2L Ref - SXS/I&W
Amana SCD25N2W Ref - SXS/I&W
Amana SCD25NL Ref - SXS/I&W
Amana SCD25NW Ref - SXS/I&W
Amana SCD25TBL Ref - SXS/I&W
Amana SCD25TBW Ref - SXS/I&W
Amana SCD25TL Ref - SXS/I&W
Amana SCD25TW Ref - SXS/I&W
Thermador SCD272T
Thermador SCD302T
Amana SCDE25J Ref - SXS/I&W
Amana SCDT20H Ref - SXS/I&W
Amana SCDT22H Ref - SXS/I&W
Amana SCDT25H Ref - SXS/I&W
Jenn-Air SCE30500B Range - S/c S/i Ele
Jenn-Air SCE30500W Range - S/c S/i Ele
Jenn-Air SCE30600B Range - S/c S/i Ele
Jenn-Air SCE30600BC Range - S/c S/i Ele
Jenn-Air SCE30600W Range - S/c S/i Ele
Jenn-Air SCE30600WC Range - S/c S/i Ele
Jenn-Air SCE4320B Range - S/c S/i Ele
Jenn-Air SCE4320W Range - S/c S/i Ele
Jenn-Air SCE4340B Range - S/c S/i Ele
Jenn-Air SCE4340B-C Range - S/c S/i Ele
Jenn-Air SCE4340W Range - S/c S/i Ele
Jenn-Air SCE4340W-C Range - S/c S/i Ele
Jenn-Air SCE70600B Range - S/c S/i Ele
Jenn-Air SCE70600W Range - S/c S/i Ele
Whirlpool SCF0710HQ00
Whirlpool SCF0710HQ01
Whirlpool SCF0710HW00
Whirlpool SCF0710HW01
Whirlpool SCF0710HW05
Whirlpool SCF0710KQ00
Whirlpool SCF0710KQ01
Whirlpool SCF0710KQ02 Chest Freezer
Whirlpool SCF0710KQ03 Chest Freezer
Whirlpool SCF0710KQ04 Chest Freezer
Whirlpool SCF1510HW00
Whirlpool SCF1510HW02
Whirlpool SCF1510HW05
Jenn-Air SCG20200A Range - S/c S/i Gas
Jenn-Air SCG20200B Range - S/c S/i Gas
Jenn-Air SCG20200W Range - S/c S/i Gas
  #2 (permalink)
Old 03-13-2009, 07:08 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Remove the microwave outer case and look for an envelope with the tech sheets and the wiring diagram. If you can post the wiring diagram it might help too.
Here are the break down diagrams and Replacement parts for GE SCB1001KSS01 | AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 03-17-2009, 08:38 AM
Junior Member
Default
Gene -- thanks for the advice. This GE design is nuts. First off, you can't get to the LED display without removing the unit from the in-wall setting. I pulled both side trim pieces, pulled the bottom trim finish, pulled 9 screws from the sides and top and the whole display unit looks like it is fastened from the inside. I pulled both access panels from the side of the unit. IE there is no way to remove the Control Display w/o pulling the unit and then taking the entire case off (guessing then I should be able to pull the single LED unit). Needless to say, that is a bigger job that it should be. Poor design from GE (probably by design to discourage owner MX). I'll pull it out this week. Thanks for the referral to the pictures. I had seen those but my unit is only labeled KSS01 on the inside of the microwave. KSS01 refers to a table-top model and I was not sure mine was the same unit I actually checked the product label on the inside of the microwave. Another disconnect.
  #4 (permalink)
Old 03-17-2009, 12:41 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Good luck and keep us posted.
__________________
  #5 (permalink)
Old 03-22-2009, 10:07 AM
Junior Member
Default
OK Gene – I pulled the MW from the wall and took off the case. Not hard, just cumbersome. About 12 screws to get the case off (sides and rear). There was no electrical/part schematic anywhere inside the unit. There is a very small Diagram on top, but it doesn’t help with this issue. I did not see any in-line fuses (course was not sure where to look) and no burnt/scorching marks anywhere inside. Of course the unit works, it is just the display. I unscrewed the 4 screws (vertical and horizontal) that hold the whole front display in place, and was able to then see all the front panel circuit boards. I removed the 20 PIN power/microprocessor cabling connector. After pulling the LED display out (2 screws, one covered by foam spacing block), I could finally free the Digitron Display [the LED Display and circuit board are one item]. At first I thought it was the 1A Fuse, It has some discoloration, but the Fuse is soldered to the board (that would probably mean an electrical shop repair). But turning the LED Display over, I was able to see that it has scorch marks in both corners (see the photos). Can you confirm the part number for me and where to buy it – it shows as in stock at ApplianceParts.com and could ship as early as Monday. Is it Part num 1657 (in the diagram), The Digitron, Part Number: AP3883432 made by GE? $92.27. Did I get it right; do you agree it is the Display? Anything else I should know or consider? I remain very unhappy that I have this repair w/ my 2 year old GE Profile unit.
  #6 (permalink)
Old 03-22-2009, 02:21 PM
Junior Member
Default
Gene -- when putting the case on (while I wait to order the part/part to ship), I came across the Schematic (in an envelope, taped to the inside of the metal case). I've posted it here in case it helps someone else (lots of info, not just electrical diagram). And even crazier, when I put the whole thing back together and put it back in the wall to use while awaiting for your answer ... plugged it in for minimal use awaiting the repair, the DIGITRON now works -- just like new. Like resetting your computer, Freaking Amazing. Time consuming, but cheap repair - $0 - , how long will it last? Cheers
  #7 (permalink)
Old 03-22-2009, 03:25 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Thanks a lot for the attachments. Hopefully the microwave will last long enough.
__________________
  #8 (permalink)
Old 06-18-2012, 04:52 PM
Junior Member
kggarcia is on a distinguished road
Default Try this!
Quote:
Try unplugging it and then plugging it back in. It just worked for me.
  #9 (permalink)
Old 01-25-2013, 05:51 PM
Junior Member
scottatbhm is on a distinguished road
Default unplugging
Unplugging reset something and now it works again, thanks for the tip.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Advantium 200 over range microwave willis1000 Microwave Repair 0 05-27-2009 04:43 AM
Advantium 120 - No microwave hubba002 Microwave Repair 0 02-01-2009 07:14 AM
GE Advantium oven - no microwave kelly123 Microwave Repair 3 12-04-2008 10:22 AM
GE Advantium 120 Microwave RichAmo Microwave Repair 0 11-04-2007 09:07 AM
GE/Advantium 1.2 Cu. Ft. Over The Range Microwave DebnJim Microwave Repair 2 09-13-2007 05:55 PM
