pimpeck
#1 Posted : Tuesday, March 10, 2009 6:26:19 AM(UTC)
pimpeck
This unit appears to work but in reality doesn't. When you go to heat something it will act like it's working. Everything turns on but it will not heat anything at all. Any Ideas on what the problem may be or what I need to replace?
TechnicianBrian
#2 Posted : Tuesday, March 10, 2009 4:41:13 PM(UTC)
TechnicianBrian
If I were playing the odds, I would say your magnetron (AP2025937) has failed. Some checks with a multimeter would confirm this, or lead us to some other item that needs to be replaced or adjusted.
pimpeck
#3 Posted : Thursday, March 12, 2009 8:19:11 AM(UTC)
pimpeck
Thanks I'll look into that. thought it may be something along those lines But I needed to hear it from someone else. What procedure do you suggest with
the multi meter?
TechnicianBrian
#4 Posted : Thursday, March 12, 2009 8:49:05 AM(UTC)
TechnicianBrian
When you remove the cover for the microwave, there should be a tech sheet on top that covers the testing of the high voltage components. What I have techs look at is get access to the transformer and check for voltage at the connectors when a cook cycle is started. If you have 120vac, then the rest of the circuit is working and now can concentrate on the high voltage portion. Follow the tech sheet and do the tests on the components. If everything else checks out, the magnetron is still the likely failure.
Dryer seems to be working but not getting hot (Dryer Repair)
by nick_jaimie 10/22/2012 6:06:36 AM(UTC)
Fridge working but not down to temp (Refrigerator & Freezer Repair)
by chocomom 5/16/2012 6:12:41 AM(UTC)
Electric Dry working but not heat? (Dryer Repair)
by lucky_me 10/4/2010 8:26:49 PM(UTC)
Roper Dryer Timer Working But Nothing ELSE (Dryer Repair)
by fixit318 11/20/2008 2:46:24 PM(UTC)
