Discuss
GE Mircrowave - Surface Lights Do Not Work
 in
Microwave Repair
I have a GE microwave model JVM1460BA01 -- One of the light blubs was burned out and when I attempted to
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » GE Mircrowave - Surface Lights Do Not Work
  #1 (permalink)
Old 11-16-2007, 12:24 PM
Aikman Aikman is offline
Junior Member
Aikman is on a distinguished road
Unhappy GE Mircrowave - Surface Lights Do Not Work
Model Number: JVM1460BA01   Brand: GE   Age: 5 - 10 years
I have a GE microwave model JVM1460BA01 -- One of the light blubs was burned out and when I attempted to remove the bad blub, the glass broke away from the metal screw housing. In the process of removing the metal housing (and failing to turn off the circuit breaker), something short circuited...Both light blubs have been replaced, and the microwave is heating just fine, but the lights will not operate. Would it be possible that the smartboard AP2026041 replacement would repair the surface lights? Thanks.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-16-2007, 02:13 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The part of the control board (aka smartboard) which operates the surface lights got damaged because of the short in the light bulb socket.
Replacing the control board should fix the problem.
- The part number for the control board AP2026041
- Here are the break down diagram for the GE microwave Model JVM1460BA01
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 11-19-2007, 04:45 AM
MicrowaveDisplaycom MicrowaveDisplaycom is offline
Member
MicrowaveDisplaycom is on a distinguished road
Default
We see this a lot.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
Post edited by admin. Reason: Advertising
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire - Changing Dual Surface Switch mrsdrjones Oven Repair (including Ranges and Cooktops) 9 11-27-2008 08:36 PM
Lights on, convection does not work BrightRhino Oven Repair (including Ranges and Cooktops) 1 12-13-2007 09:44 PM
freezer and fridge lights do not work cat416 Refrigerator & Freezer Repair 1 10-16-2007 12:35 PM
only lights work no cooling or fans peppermoosh Refrigerator & Freezer Repair 0 09-03-2007 10:02 AM
Hot Surface Signal Light Tigerest45 Oven Repair (including Ranges and Cooktops) 0 08-22-2007 12:03 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
