| » Microwave Handle |
LinkBack (2) | Thread Tools | Search this Thread | Display Modes |
__________________
Professional appliance repair in Orange County, California. |
I installed the new handle for the Kitchenaid KHMS155LSS0. I have the stainless steel model.
The instructions on the forum were a little hard for me to get so I figure I would post pictures to help the next guy out. The outside of the door that the stainless steel is attached to actually has little hook claws that grab onto the inner black part of the door. Check out the pictures: ![]() ![]() ![]() Take the 3 little screws out of the side. Then you need to pry the outside of the door from the inside of the door. The outside kind of snaps over the inside and stays in place with the little claws that snap into the holes. I suggest using a butter knife to pry the outside up from the inside part a little then use a wooden paint stirrer or wooden shim to really pry it up and off. Using wood keeps you from marring the plastic. You have to get the hooks on the outside door up and over the holes on the inside part of the door. Do it one at a time and the door will come apart fairly easy. After you done your work with installing the handle or whatever your doing, you can just shut the inside part of the door onto the main part of the microwave. After I did that, I just snapped the outside part back on. Hope this helps someone else out there on the internets! |
Thank you very much for such useful information and pictures.
__________________
I have KitchenAid KHMS147KSS with a broken handle. I followed the instructions on how to remove #2 and was successful to get it removed without breaking it. But the frustration came after that when i could not find any screws which hold the handle. They are obviously behind #4. And i was not able to even slightly shake it, it stays solid. Are there any ideas? it becomes really frustrated.
Thanks, Yakov Last edited by Yakov : 04-13-2009 at 10:25 PM. |
Looks like you have to remove the outer door panel (#10) too as shown on the above pictures posted by ianfranklin.
__________________
You are welcome. I'm glad you were able to fix it.
__________________
Quote:
I too have a broken handle. It is broken at the top screw, which I can see from the back. The bottom screw is hidden. I would imagine the repair is similar, but I can't get the frame off. Any suggestions?
The video clip on the second page of this thread might help.
__________________
LinkBack to this Thread: http://forum.appliancepartspros.com/microwave-repair/255-microwave-handle.html
| Posted By | For | Type | Date |
| AR15.COM :: Forums :: Any KitchenAid Repair person in da house? | This thread | Refback | 02-15-2008 07:33 PM |
| YouTube - Touch Free Microwave Door | This thread | Refback | 01-23-2008 08:02 AM |
| Display Modes | |
| Microwave interior light bulb replacement | Ardith | Microwave Repair | 5 | 10-02-2009 08:23 PM |
| Handle Replacement | Tim | Microwave Repair | 16 | 03-20-2009 08:11 PM |
| Replacing door panel & handle | Laurence | Microwave Repair | 2 | 01-13-2008 09:09 PM |
| Microwave plugged on wrong socket is dead | danny2001s | Microwave Repair | 1 | 07-28-2007 07:13 PM |
| How to put new handle on | shelly | Microwave Repair | 1 | 07-24-2007 01:03 PM |
