Discuss
Microwave Handle
 in
Microwave Repair
Once the black inside liner is partially removed (very difficult), the screws for the handle are still not visible. Any
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Microwave Handle
  #101 (permalink)
Old 11-20-2013, 11:14 AM
Junior Member
tsackett@embarqmail.com is on a distinguished road
Default Doesn't Work for the MH2155XPS
Once the black inside liner is partially removed (very difficult), the screws for the handle are still not visible. Any suggestions?
  #102 (permalink)
Old 11-20-2013, 11:29 AM
Junior Member
Mstone8675@optonline.net is on a distinguished road
Default
Quote:
You need to remove the black liner completely and the screws are visible them
  #103 (permalink)
Old 11-23-2013, 04:03 AM
Junior Member
Default
Thanks for the reply. I actually figured it out after posting on the forum.
It's a very difficult process, and it's actually not the liner that needs to be removed. In fact, even if you remove the liner completely for whatever reason, the screws are still not accessible, or even visible. The exterior fascia of the door must be removed from the frame. The interior liner can be removed, but does not need to be. With the way mine ended up getting cracked and torn, I wouldn't recommend even messing with the liner on this model.
Oh, and keep a good hold on the glass. The glass fell out of mine, five feet to the floor, but luckily didn't break when it hit the tile.
Last edited by tsackett@embarqmail.com : 11-23-2013 at 04:08 AM. Reason: Added a little more information about the liner.
  #104 (permalink)
Old 08-23-2014, 02:17 PM
Junior Member
MsBshi is on a distinguished road
Default
This does not work for Frigidaire model FMV157CG. There is another layer inside the door that must be removed. Is this even possible?
  #105 (permalink)
Old 11-08-2014, 05:53 PM
Junior Member
Chemosh013 is on a distinguished road
Default Kitchenaid khms155lss-3 Door Replacement
I tried a million different things but this page finally keyed me in on how to replace this. You have to put about 8 butter knives in to get the hooks out and then apply pressure to about half of them. The door pops off and you have access to the handle.
How to Replace the Door Handle on a KitchenAid Microwave Hood | eHow
  #106 (permalink)
Old 12-07-2014, 11:40 AM
Junior Member
ApplianceAvid is on a distinguished road
Thumbs up Thanks Chemosh013
I just replaced my handle for the KHMS155LSS1 thanks to the post about the 8 butter knives. I decided to post a reply with pictures to help others out since this kept me from doing major damage to my microwave. There are 9 plastic hooks in the bottom outer cover, 9 at the top and a few at the inner edge. I did not count but it may be 5 or 6. I first used a plastic putty knife thinking the plastic would not damage anything, but I damaged 6 of the bottom hooks before I found this page and used 9 butter knifes.
A metal putty knife is thinner and easier to slide into the plastic outer cover and inner liner. You can also feel where the hooks are with the putty knife and pry it open a little to know where to put the butter knifes. Like Chemosh013 said, you pry down on about 4 of the butter knifes just enough so the hooks are released from the holes. Since I had already broken 6 of the bottom plastic hooks, my knives all fell down to the stove top when the remaining three bottom hooks were released. I had put all 9 knives in since I was not sure at first if there were still small hooks left that would catch.
After releasing the bottom hooks, you may need two people to help release the top hooks because the outer cover can fall and break the glass. There are no hooks on the side where the 3 screws are so the inner hooks do not do much once the bottom and top hooks are released.
Hope this helps other people.
  #107 (permalink)
Old 12-29-2014, 11:07 AM
Junior Member
mtburr is on a distinguished road
Default Video explaining how to replace microwave handle
I made this short video to explain how to replace the door handle on an Estate by Whirlpool microwave oven.
http://youtu.be/1kAAOrU-40c
  #108 (permalink)
Old 01-27-2015, 12:48 PM
Junior Member
samsaw is on a distinguished road
Default
Thank you ApplianceAvid for fantastic photos! I have been looking for some help with the same microwave KHMS155LSS from KitchenPain (more Pain than Aid!!).
I gave up on my first attempt after prying the choke frame (and breaking it partially). With these photos I am tempted to give it a second try.
  #109 (permalink)
Old 01-27-2015, 12:49 PM
Junior Member
Default
I was able to pry off the outer layer based on the steps listed by ApplianceAvid.
One improvisation I did was instead of using butter knives, I used obsolete credit cards to slide between the plastic hooks and the groove of the inner frame thereafter the outer shell came off easily.
I did remove (destroy) the choke frame which made it a tad bit simpler to see how much gap I needed to create to slide in the cc's in the correct positions.
Snapping the out frame on back after the door handle replacement was indeed a "snap"
It took about 45 mins start to end! now waiting on the choke frame delivery from Appliancepartspros.
Thank you once again for posting the pictures, it made it a lot more easy.
  #110 (permalink)
Old 03-19-2015, 07:24 AM
Junior Member
musitcat is on a distinguished road
Default Screws for KitchenAid Microwave KHMS155L Handle
The handle broke of my Kitchen Aid Microwave KHMS155L. I ordered a new handle. However the old handle was attached by white plastic tubes that cracked when the handle broke off. Are there screws or another attachment I could purchase at someplace like Home Depot to attach? If screws, could you please tell me what size I would need?
Thank you!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://forum.appliancepartspros.com/microwave-repair/255-microwave-handle.html
Posted By For Type Date
Part Details - GE Door assembly wh, part number: AP3204660 This thread Refback 04-05-2011 10:43 AM
WHIRLPOOL R0130651 Handle(stn stl), AP4247365 | AppliancePartsPros.com This thread Refback 04-01-2011 08:17 PM
Part Details - WHIRLPOOL Microwave vent grill, part number: AP3119799 This thread Refback 03-31-2011 10:46 AM
Part Details - WHIRLPOOL Handle(stn stl), part number: AP4247365 This thread Refback 03-29-2011 05:16 PM
WHIRLPOOL 8169738 Door handle, black for stainless model, AP3034209 | AppliancePartsPros.com This thread Refback 03-29-2011 09:57 AM
WHIRLPOOL 8183851 Microwave vent grill, AP3119799 | AppliancePartsPros.com This thread Refback 03-29-2011 09:48 AM
Part Details - GE Handle assembly w, part number: AP2623338 This thread Refback 03-28-2011 12:46 PM
Part Details - FRIGIDAIRE HANDLE, part number: AP4433631 This thread Refback 03-26-2011 06:59 AM
GE WB15X310 Handle assembly w, AP2623338 | AppliancePartsPros.com This thread Refback 03-24-2011 01:41 PM
WHIRLPOOL 8184264 Door handle, AP3137838 | AppliancePartsPros.com This thread Refback 03-23-2011 01:40 PM
Part Details - GE Door handle, part number: AP3184331 This thread Refback 03-21-2011 07:49 PM
Part Details - WHIRLPOOL Door handle, part number: AP3137838 This thread Refback 03-19-2011 01:10 PM
GE WB15X10069 Door handle, AP3184331 | AppliancePartsPros.com This thread Refback 03-19-2011 08:04 AM
FRIGIDAIRE 5304472481 HANDLE, AP4433631 | AppliancePartsPros.com This thread Refback 03-16-2011 09:38 AM
Part Details - WHIRLPOOL Door handle, part number: AP3137838 This thread Refback 03-15-2011 12:36 PM
Part Details - WHIRLPOOL Door handle, black for stainless model, part number: AP3034209 This thread Refback 03-14-2011 08:14 AM
Part Details - WHIRLPOOL Handle, door (biscuit), part number: AP3033676 This thread Refback 03-13-2011 09:04 AM
Whirlpool W10272107 Handle, Door, AP4453258 | AppliancePartsPros.com This thread Refback 03-12-2011 09:48 AM
Part Details - WHIRLPOOL Door handle, part number: AP3137838 This thread Refback 03-11-2011 10:22 AM
Part Details - WHIRLPOOL Door handle, black for stainless model, part number: AP3034209 This thread Refback 03-11-2011 05:18 AM
GE WB15X10045 Assembly - handle, AP2021195 | AppliancePartsPros.com This thread Refback 03-09-2011 08:08 PM
Part Details - GE Door handle, part number: AP3184331 This thread Refback 03-09-2011 06:03 PM
Part Details - WHIRLPOOL Handle, door (biscuit), part number: AP3033676 This thread Refback 03-09-2011 08:22 AM
FRIGIDAIRE 5304472481 HANDLE, AP4433631 | AppliancePartsPros.com This thread Refback 03-08-2011 04:05 PM
Part Details - GE Handle assembly w, part number: AP2623338 This thread Refback 03-08-2011 12:45 PM
Part Details - FRIGIDAIRE HANDLE, part number: AP4433631 This thread Refback 03-07-2011 06:25 PM
Part Details - GE Assembly - handle, part number: AP2021195 This thread Refback 03-06-2011 12:54 PM
Part Details - WHIRLPOOL Handle(stn stl), part number: AP4247365 This thread Refback 03-06-2011 08:24 AM
Part Details - Whirlpool Handle, Door, part number: AP4453258 This thread Refback 03-06-2011 08:11 AM
Part Details - Whirlpool Handle, Door, part number: AP4453258 This thread Refback 03-04-2011 07:08 AM
Part Details - GE Door handle, part number: AP3184331 This thread Refback 03-02-2011 08:08 AM
Part Details - GE Handle assembly, part number: AP2021140 This thread Refback 02-19-2011 11:19 AM
Part Details - FRIGIDAIRE HANDLE, part number: AP4433631 This thread Refback 02-19-2011 07:09 AM
Part Details - FRIGIDAIRE HANDLE, part number: AP4433631 This thread Refback 02-18-2011 07:52 PM
Kitchen Aid Oven Parts and Kitchen Aid Oven Repair Help from AppliancePartsPros.com This thread Refback 11-06-2010 06:57 AM
Kitchen Aid Parts and Kitchen Aid Repair Help from AppliancePartsPros.com This thread Refback 10-06-2010 07:15 AM
Kitchen Aid Microwave Parts and Kitchen Aid Microwave Repair Help from AppliancePartsPros.com This thread Refback 05-15-2010 03:09 PM
Whirlpool Microwave Parts and Whirlpool Microwave Repair Help from AppliancePartsPros.com This thread Refback 09-02-2009 12:18 PM
Sears Microwave Parts and Sears Microwave Repair Help from AppliancePartsPros.com This thread Refback 06-08-2009 07:43 AM
Kenmore Parts and Kenmore Repair Help from AppliancePartsPros.com This thread Refback 05-26-2009 06:05 PM
GE Microwave Parts and GE Microwave Repair Help from AppliancePartsPros.com This thread Refback 05-26-2009 01:35 PM
Kenmore Microwave Parts and Kenmore Microwave Repair Help from AppliancePartsPros.com This thread Refback 05-25-2009 06:43 PM
AR15.COM :: Forums :: Any KitchenAid Repair person in da house? This thread Refback 02-15-2008 06:33 PM
YouTube - Touch Free Microwave Door This thread Refback 01-23-2008 07:02 AM
Similar Threads
Microwave handle firat Microwave Repair 6 12-24-2011 10:05 AM
microwave handle gdevas Microwave Repair 1 10-30-2009 08:39 AM
microwave handle vsforbes Microwave Repair 0 08-04-2009 09:02 AM
Microwave Handle tyohe@yoheconsulting.com Microwave Repair 4 04-08-2009 08:36 AM
Microwave handle tamerson_1 Microwave Repair 1 09-19-2007 06:55 PM
