Everything was working except occasionally it would not cook. By opening the door and trying again it would cook. Over time, it took more attempts. Now it will not cook after a dozen attempts. Everything else appears to be working. Is there an obvious failing/failed part? If I need to diagnose the problem, how do I find the procedure?
