Discuss
Maytag only heats if vent is on
 in
Microwave Repair
I live in rural Alaska with the nearest repairman a $300 flight away. My over the range microwave suddenly quit
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Maytag only heats if vent is on
  #1 (permalink)
Old 06-12-2011, 05:24 PM
Junior Member
cdvfam is on a distinguished road
Question Maytag only heats if vent is on
Model Number: MMV1153AA   Brand: Maytag   Age: 1 - 5 years
I live in rural Alaska with the nearest repairman a $300 flight away. My over the range microwave suddenly quit heating. The light, vent, timer, and control panel all work. The turn-table spins and everything looks and sounds like normal but the microwave doesn't heat. After reading different forums, someone mentioned that their microwave would only heat if the vent was turned on low. I tried that and if I turn the vent on, the microwave does heat. This seems to me only a temporary fix. Does anyone have any advice as to what could be wrong and if it can be fixed by a layman? Do I need a new microwave? I obviously hope that it's a cheap and easy fix but I can't live without my microwave. Thanks for any help!
Ads By Google
Related Models
Maytag MMV1153AAB Mwave - Mounted Over Range/wo
Maytag MMV1153AAW Mwave - Mounted Over Range/wo
Maytag MMV1153BAB Mwave - Mounted Over Range/wo
Maytag MMV1153BAQ Mwave - Mounted Over Range/wo
Maytag MMV1153BAS Mwave - Mounted Over Range/wo
Maytag MMV1153BAW Mwave - Mounted Over Range/wo
Maytag MMV4184AAB Mwave - Mounted Under Cabinet
Maytag MMV4184AAQ Mwave - Mounted Under Cabinet
Maytag MMV4184AAW Mwave - Mounted Under Cabinet
Maytag MMV4205AAB Mwave - Mounted Over Range/wo
Maytag MMV4205AAQ Mwave - Mounted Over Range/wo
Maytag MMV4205AAS Mwave - Mounted Over Range/wo
Maytag MMV4205AAW Mwave - Mounted Over Range/wo
Maytag MMV4205BAB Mwave - Mounted Over Range/wo
Maytag MMV4205BAQ Mwave - Mounted Over Range/wo
Maytag MMV4205BAS Mwave - Mounted Over Range/wo
Maytag MMV4205BAW Mwave - Mounted Over Range/wo
Maytag MMV5000ADA Mwave - Mounted Under Cabinet
Maytag MMV5000ADB Mwave - Mounted Under Cabinet
Maytag MMV5000ADW Mwave - Mounted Under Cabinet
Maytag MMV5000BAB Mwave - Mounted Under Cabinet
Maytag MMV5000BAC Mwave - Mounted Under Cabinet
Maytag MMV5000BAQ Mwave - Mounted Under Cabinet
Maytag MMV5000BAW Mwave - Mounted Under Cabinet
Maytag MMV5000BDB Mwave - Mounted Under Cabinet
Maytag MMV5000BDC Mwave - Mounted Under Cabinet
Maytag MMV5000BDQ Mwave - Mounted Under Cabinet
Maytag MMV5000BDW Mwave - Mounted Under Cabinet
Maytag MMV5100AAB Mwave - Mounted Under Cabinet
Maytag MMV5100AAQ Mwave - Mounted Under Cabinet
Maytag MMV5100AAS Mwave - Mounted Under Cabinet
Maytag MMV5100AAW Mwave - Mounted Under Cabinet
Maytag MMV5156AAB Mwave - Mounted Under Cabinet
Maytag MMV5156AAQ Mwave - Mounted Under Cabinet
Maytag MMV5156AAS White Westinghouse/refrigerator
Maytag MMV5156AAW Mwave - Mounted Under Cabinet
Maytag MMV5156ACB Mwave - Mounted Under Cabinet
Maytag MMV5156ACQ Mwave - Mounted Under Cabinet
Maytag MMV5156ACS Mwave - Mounted Under Cabinet
Maytag MMV5156ACW Mwave - Mounted Under Cabinet
Maytag MMV5165AAB Mwave - Mounted Over Range/wo
Maytag MMV5165AAQ Mwave - Mounted Over Range/wo
Maytag MMV5165AAS Mwave - Mounted Over Range/wo
Maytag MMV5165AAW Mwave - Mounted Over Range/wo
Maytag MMV5165BAB Mwave - Mounted Over Range/wo
Maytag MMV5165BAQ Mwave - Mounted Over Range/wo
Maytag MMV5165BAS Mwave - Mounted Over Range/wo
Maytag MMV5165BAW Mwave - Mounted Over Range/wo
Maytag MMV5186AAB Mwave - Mounted Under Cabinet
Maytag MMV5186AAQ Mwave - Mounted Under Cabinet
Maytag MMV5186AAS Mwave - Mounted Under Cabinet
Maytag MMV5186AAW Mwave - Mounted Under Cabinet
Maytag MMV5186ACB Mwave - Mounted Under Cabinet
Maytag MMV5186ACQ Mwave - Mounted Under Cabinet
Maytag MMV5186ACS Mwave - Mounted Under Cabinet
Maytag MMV5186ACW Mwave - Mounted Under Cabinet
Maytag MMV5207AAB Mwave - Mounted Over Range/wo
Maytag MMV5207AAQ Mwave - Mounted Over Range/wo
Maytag MMV5207AAS Mwave - Mounted Over Range/wo
Maytag MMV5207AAW Mwave - Mounted Over Range/wo
Maytag MMV5207ACB Mwave - Mounted Over Range/wo
Maytag MMV5207ACQ Mwave - Mounted Over Range/wo
Maytag MMV5207ACS Mwave - Mounted Over Range/wo
Maytag MMV5207ACW Mwave - Mounted Over Range/wo
Maytag MMV5207BAB Mwave - Mounted Over Range/wo
Maytag MMV5207BAQ Mwave - Mounted Over Range/wo
Maytag MMV5207BAS Mwave - Mounted Over Range/wo
Maytag MMV5207BAW Mwave - Mounted Over Range/wo
Maytag MMV5207BCB Mwave - Mounted Over Range/wo
Maytag MMV5207BCQ Mwave - Mounted Over Range/wo
Maytag MMV5207BCS Mwave - Mounted Over Range/wo
Maytag MMV5207BCW Mwave - Mounted Over Range/wo
Maytag MMV6178AAB Microwave - Convection
Maytag MMV6178AAQ Microwave - Convection
Maytag MMV6178AAS Microwave - Convection
Maytag MMV6178AAW Microwave - Convection
Maytag MMW5527BAB Walloven - S/c Ele
Maytag MMW5527BAW Walloven - S/c Ele
Maytag MMW5527CAB Walloven - S/c Ele
Maytag MMW5527CAW Walloven - S/c Ele
Maytag MMW5530BAB Walloven - S/c Ele
Maytag MMW5530BAW Walloven - S/c Ele
Maytag MMW5530CAB Walloven - S/c Ele
Maytag MMW5530CAW Walloven - S/c Ele
Maytag MMW5530DAB Walloven - S/c Mwave Ele
Maytag MMW5530DAW Walloven - S/c Mwave Ele
Norge MN15E-5 Mwave - Cntrtp / Stand Alone
Norge MN15F-14T Mwave - Cntrtp / Stand Alone
Norge MN15FN-14T Mwave - Cntrtp / Stand Alone
Norge MN46G-14T Mwave - Cntrtp / Stand Alone
Norge MN46GN-14T Mwave - Cntrtp / Stand Alone
Maytag MO1450BA Mwave - Mounted Over Range/wo
Maytag MO1450CA Mwave - Mounted Over Range/wo
Maytag MO1450WA Mwave - Mounted Over Range/wo
Maytag MO1650BA Mwave - Mounted Over Range/wo
Maytag MO1650CA Mwave - Mounted Over Range/wo
Maytag MO1650WA Mwave - Mounted Over Range/wo
Magic Chef MOD61AD Mwave - Mounted Over Range/wo
Magic Chef MOD61WH Mwave - Mounted Over Range/wo
Magic Chef MOD62AD Mwave - Mounted Over Range/wo
Magic Chef MOD62WH Mwave - Mounted Over Range/wo
Magic Chef MOD62WOW Mwave - Mounted Over Range/wo
Magic Chef MOD64WOW Mwave - Mounted Over Range/wo
Magic Chef MOD65B Mwave - Mounted Over Range/wo
Magic Chef MOD65WOW Mwave - Mounted Over Range/wo
Whirlpool MODEL_PBK0190
Whirlpool MODEL_PBK0191
Whirlpool MODEL_PBK0838
Magic Chef MODW1A Mwave - Mounted Over Range/wo
Magic Chef MODW1V Mwave - Mounted Over Range/wo
Amana MP1.A Commercial Microwaves
Amana MP1.B Commercial Microwaves
Amana MPD218-02 Mwave - Family Size (60 Hz)
Amana MPD219-02 Mwave - Family Size (60 Hz)
Frigidaire MPF200PBDA Frg(v2) / Gas Range
Frigidaire MPF200PBWA Frg(v1) / Gas Range
Frigidaire MPF300BPDA Gib(v9) / Gas Range
Frigidaire MPF300PBDA Frg(v1) / Gas Range
Frigidaire MPF300PBDB Wwh(v1) / Gas Range
Frigidaire MPF300PBDC Frg(v1) / Gas Range
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Only heats when vent fan is on Staging2000 Microwave Repair 0 04-09-2010 06:47 AM
THERMADOR Cook N Vent Vent issue PaulaM Oven Repair (including Ranges and Cooktops) 0 06-25-2009 06:59 PM
Maytag MD9316 no longer heats up Jake53 Dryer Repair 1 06-24-2009 04:51 PM
Maytag Gas Dryer Heats One Cycle glassbender Dryer Repair 3 02-13-2009 04:08 AM
Converting a Vent hood to non-vent recirculating mtcycle Heating, Ventilation, and Air Conditioning (HVAC) 0 02-09-2009 12:34 PM
