Discuss
Business owner
 in
Microwave Repair
I suspect lose connection in the power baord. the power board, looks like, it suppose to slide upward, but it
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Business owner
  #1 (permalink)
Old 11-13-2007, 10:46 PM
ibrahimdd ibrahimdd is offline
Junior Member
ibrahimdd is on a distinguished road
Exclamation Business owner
Model Number: JVM 186 1SD 002   Brand: GE   Age: 1 - 5 years
I suspect lose connection in the power baord. the power board, looks like, it suppose to slide upward, but it won't, even though I use extreem force, like big hammer.
Abe
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-14-2007, 08:36 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
In order to remove the control panel you have to remove the top grill first and then remove the screw, holding the control panel.
What exactly is wrong with your microwave? Does it exist after a big hammer used?
- Here are the break down diagrams for the GE microwave Model JVM1861SD002
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 11-15-2007, 09:09 AM
Junior Member
Exclamation
Gene...I am 70, I start at 20, There are no scews, Panel suppose to slide upward, Has 6 fingers sticking thrue the frame" ---1" in this shape, saw hundreds but not this type.
All have screws top and bottom, this has no screws. could not push it up, so with a piece of wood and a hammer, I tried to push up in case it is stuck, no move...
Thank you for your help, try again
This micro. has no print inside as normal. Does GE has techn. support.
Abe.... tel.&fax 707 586 0543
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
