Discuss
Everything works the same but it buzzes louder and generates no heat
 in
Microwave Repair
Hi there - Our microwave suddenly started making a louder buzz and stopped generating any heat. Everything else works fine (light,
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Everything works the same but it buzzes louder and generates no heat
  #1 (permalink)
Old 02-26-2009, 08:59 AM
talipini talipini is offline
Junior Member
talipini is on a distinguished road
Default Everything works the same but it buzzes louder and generates no heat
Model Number: MH6150xlb   Brand: Whirlpool   Age: 5 - 10 years
Hi there - Our microwave suddenly started making a louder buzz and stopped generating any heat. Everything else works fine (light, turntable etc). I probably need to test diode, capacitor and magnetron - Any instructions on how to go about opening it up and checking? Any other things I should check before I open it up?
Related Models
Whirlpool MH6150XLB0
Whirlpool MH6150XLB1 Microwave Hood Combination
Whirlpool MH6150XLQ0
Whirlpool MH6150XLQ1 Microwave Hood Combination
Whirlpool MH6150XLS0
Whirlpool MH6150XLS1 Microwave Hood Combination
Whirlpool MH6150XLT0
Whirlpool MH6150XLT1 Microwave Hood Combination
Whirlpool MH6150XMB0
Whirlpool MH6150XMB1 Microwave Hood Combination
Whirlpool MH6150XMQ0
Whirlpool MH6150XMQ1 Microwave Hood Combination
Whirlpool MH6150XMS0
Whirlpool MH6150XMS1 Microwave Hood Combination
Whirlpool MH6150XMT0
Whirlpool MH6150XMT1 Microwave Hood Combination
Whirlpool MH6151XHB0
Whirlpool MH6151XHB1
Whirlpool MH6151XHQ0
Whirlpool MH6151XHQ1
Whirlpool MH6151XHT0
Whirlpool MH6151XHT1
Whirlpool MH6300XM0
Whirlpool MH6300XM1
Whirlpool MH6600XM0
Whirlpool MH6600XM1
Whirlpool MH6600XM2
Whirlpool MH6600XV0
Whirlpool MH6600XV1
Whirlpool MH6600XW0
Whirlpool MH6600XW1
Whirlpool MH6600XX0
Whirlpool MH6700XM0
Whirlpool MH6700XM1
Whirlpool MH6700XM2
Whirlpool MH6700XM3
Whirlpool MH6700XV0
Whirlpool MH6700XV1
Whirlpool MH6700XW0
Whirlpool MH6700XW1
Whirlpool MH6700XX0
Whirlpool MH6701XW0
Whirlpool MH6701XW1
Whirlpool MH6701XX0
Whirlpool MH7100XYB0
Whirlpool MH7100XYQ0
Whirlpool MH7110XBB0
Whirlpool MH7110XBB1
Whirlpool MH7110XBB2
Whirlpool MH7110XBB3
Whirlpool MH7110XBB4
Whirlpool MH7110XBB5
Whirlpool MH7110XBB6
Whirlpool MH7110XBQ0
Whirlpool MH7110XBQ1
Whirlpool MH7110XBQ2
Whirlpool MH7110XBQ3
Whirlpool MH7110XBQ4
Whirlpool MH7110XBQ5
Whirlpool MH7110XBQ6
Whirlpool MH7115XBB0
Whirlpool MH7115XBB1
Whirlpool MH7115XBB2
Whirlpool MH7115XBB4
Whirlpool MH7115XBB5
Whirlpool MH7115XBB6
Whirlpool MH7115XBQ0
Whirlpool MH7115XBQ1
Whirlpool MH7115XBQ2
Whirlpool MH7115XBQ4
Whirlpool MH7115XBQ5
Whirlpool MH7115XBQ6
Whirlpool MH7115XBZ0
Whirlpool MH7115XBZ1
Whirlpool MH7115XBZ2
Whirlpool MH7115XBZ4
Whirlpool MH7115XBZ5
Whirlpool MH7115XBZ6
Whirlpool MH7130XEB0
Whirlpool MH7130XEB1
Whirlpool MH7130XEB2
Whirlpool MH7130XEQ0
Whirlpool MH7130XEQ1
Whirlpool MH7130XEQ2
Whirlpool MH7130XEQ3
Whirlpool MH7130XEZ0
Whirlpool MH7130XEZ1
Whirlpool MH7130XEZ2
Whirlpool MH7135XEB0
Whirlpool MH7135XEB1
Whirlpool MH7135XEB2
Whirlpool MH7135XEQ0
Whirlpool MH7135XEQ1
Whirlpool MH7135XEQ2
Whirlpool MH7140XFB0
Whirlpool MH7140XFB1
Whirlpool MH7140XFQ0
Whirlpool MH7140XFQ1
Whirlpool MH7140XFZ0
Whirlpool MH7140XFZ1
Whirlpool MH7155XMB0 Microwave Hood Combination
Whirlpool MH7155XMQ0 Microwave Hood Combination
Whirlpool MH7155XMS0 Microwave Oven
Whirlpool MH7155XMT0 Microwave Hood Combination
Whirlpool MH8150XJB0
Whirlpool MH8150XJB1 Microwave Hood Combination
Whirlpool MH8150XJQ0
Whirlpool MH8150XJQ1 Microwave Hood Combination
Whirlpool MH8150XJT0
Whirlpool MH8150XJT1 Microwave Hood Combination
Whirlpool MH8150XJZ0
Whirlpool MH8150XJZ1 Microwave Hood Combination
Whirlpool MH8150XMB0 Microwave Hood Combination
Whirlpool MH8150XMB2 Microwave Hood Combination
Whirlpool MH8150XMQ0 Microwave Hood Combination
Whirlpool MH8150XMQ2 Microwave Hood Combination
Whirlpool MH8150XMT0 Microwave Hood Combination
Whirlpool MH8150XMT2 Microwave Hood Combination
Whirlpool MH8150XMZ0 Microwave Hood Combination
Whirlpool MH8150XMZ2 Microwave Hood Combination
  #2 (permalink)
Old 02-26-2009, 01:02 PM
TechnicianBrian's Avatar
TechnicianBrian TechnicianBrian is offline
Senior Expert
APP Volunteer
TechnicianBrian is on a distinguished road
Default
You are looking in the right area. Most likely the diode has failed and may have damaged the magnetron. As for opening up the unit, remove it from the wall and start pulling screws. Pay attension to which ones go where as there are different types. Once the cover is removed, the high voltage section is on the right. Discharge the capacitor using a screwdriver or pliers with insulated handles before touching anything. With the cover removed, there should be a tech sheet in a pocket on top of the cavity which has component specifications.
__________________
TechnicianBrian
TechnicianBrian.com
AllTechAppliance.com
  #3 (permalink)
Old 02-26-2009, 06:11 PM
xiwang315 xiwang315 is offline
Junior Member
xiwang315 is on a distinguished road
Default Who needs that much velcro?
Why would anyone need that much velcro? These guys sell it by the roll http://www.**********************.co...llaneous_1.htm and is
hook and look and velcro the same thing?
  #4 (permalink)
Old 02-26-2009, 07:18 PM
Junior Member
Default Any suggestions on the meter
Brian - I don't have a quality meter, so I was going to buy one. Any suggestions on a reasonable one that can help me do the job but draining my wallet? Thanks.
  #5 (permalink)
Old 02-26-2009, 07:31 PM
Senior Expert
APP Volunteer
Default
I am not the person to suggest a meter as all mine are Flukes and not what most people would consider reasonable, but you really only need to do some basic checks so most meters should give you what you need. The diode check is only going to work on more expensive meters, but if you are hearing a buzzing sound, you may actually find the diode has overheated and possibly cracked. If it is, no need to check it with a meter. The magnetron and capacitor are basic checks too.
__________________
TechnicianBrian
TechnicianBrian.com
  #6 (permalink)
Old 02-26-2009, 07:33 PM
Junior Member
Default
Thanks Brian! I was looking for Diode part on different websites but I don't see anywhere. Is it normally sold under a different name?
  #7 (permalink)
Old 02-26-2009, 07:45 PM
Senior Expert
APP Volunteer
Default
They are rarely called diodes (AP4352540) in the parts catalogs, but more often rectifiers, or simply HV wire.
__________________
TechnicianBrian
TechnicianBrian.com
  #8 (permalink)
Old 02-26-2009, 08:07 PM
Junior Member
Default
thanks for all the help Brian!!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven Won't Heat & Touchpad Buzzes donhogo Oven Repair (including Ranges and Cooktops) 0 02-25-2010 10:09 AM
GE Gas Dryer Works but Buzzes dmp8453 Dryer Repair 0 01-26-2010 07:53 PM
microwave does not heat, smells like its burning and buzzes doogie48084 Microwave Repair 3 05-28-2009 03:38 PM
MICROWAVE makes louder noise and does not heat dimark3 Microwave Repair 1 05-25-2009 05:29 PM
dishwasher generates no heat america1 Dishwasher Repair 1 11-23-2008 08:31 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
