Discuss
Emerson fuse
 in
Microwave Repair
I'm having trouble finding a fuse for my microwave. It is a short ceramic fuse. It reads f15h250v. I can
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Emerson fuse
  #1 (permalink)
Old 02-23-2009, 06:53 PM
Member
bluefitness is on a distinguished road
Default Emerson fuse
Model Number: MW8781RD   Brand: -brand-   Age: 1 - 5 years
I can only find ceramic fuses that are 1 1/4 in. If someone could help me locate one, I would greatly appreciate it.
I also thought about just buying a fuse holder and using the longer fuse. The only problem I see with this is that the fuse goes into a solid state board (noise filter). I could put a slug in it and just run the fuse after the noise filter. I could also put the fuse in before the noise filter with some modifications.
Ads By Google
Related Models
Whirlpool MW8800XR0
Whirlpool MW8800XS0
Whirlpool MW8800XS1
Whirlpool MW8800XS2
Whirlpool MW8800XS4
Maytag MW880BKA Mwave - Cntrtp / Stand Alone
Maytag MW880BKA/XAA Mwave - Cntrtp / Stand Alone
Maytag MW880BLA Mwave - Cntrtp / Stand Alone
Maytag MW880BLA/XAA Mwave - Cntrtp / Stand Alone
Maytag MW880BSA Mwave - Cntrtp / Stand Alone
Maytag MW880BSA/XAA Mwave - Cntrtp / Stand Alone
Maytag MW880GRA Mwave - Cntrtp / Stand Alone
Maytag MW880GRA/XAA Mwave - Cntrtp / Stand Alone
Maytag MW880KSA Mwave - Cntrtp / Stand Alone
Maytag MW880KSA/XAA Mwave - Cntrtp / Stand Alone
Maytag MW880RDA Mwave - Cntrtp / Stand Alone
Maytag MW880RDA/XAA Mwave - Cntrtp / Stand Alone
Maytag MW880RSA Mwave - Cntrtp / Stand Alone
Maytag MW880RSA/XAA Mwave - Cntrtp / Stand Alone
Maytag MW888STB Mwave - Cntrtp / Stand Alone
Whirlpool MW8900XS0
Whirlpool MW8900XS1
Whirlpool MW8900XS2
Whirlpool MW8900XS3
Whirlpool MW8900XS4
Whirlpool MW8900XS5
Whirlpool MW8900XS6
Whirlpool MW8901XS0
Maytag MW945WB Mwave - Cntrtp / Stand Alone
Maytag MW965BB Mwave - Cntrtp / Stand Alone
Maytag MW965BB/XAA Mwave - Cntrtp / Stand Alone
Maytag MW965WB Mwave - Cntrtp / Stand Alone
Maytag MW965WB/XAA Mwave - Cntrtp / Stand Alone
Amana MW96T Mwave - Cntrtp / Stand Alone
Maytag MW96T  Mwave - Cntrtp / Stand Alone
Magic Chef MWCP1085 Washer - Top Loading
Magic Chef MWCP1085-A Washer - Top Loading
Amana MWD365 Mwave - Mounted Over Range/wo
Amana MWD366 Mwave - Mounted Over Range/wo
Amana MWD36610 Mwave - Family Size (60 Hz)
Amana MWD366MN002 Range - S/c S/i Ddraft Gas
Maytag MWF2100AWB Water Filtration System
Maytag MWF2100AWS Water Filtration System
Maytag MWF3100AWB Water Filtration System
Maytag MWF3100AWS Water Filtration System
Maytag MWF3500AWS Water Filtration System
Maytag MWF4100 Water Filtration System
Maytag MWF4100AWS Water Filtration System
Maytag MWF4200 Water Filtration System
Maytag MWF4200AWS Water Filtration System
Maytag MWF4300 Water Filtration System
Maytag MWF4300AWS Water Filtration System
Maytag MWF4500AWS Water Filtration System
Whirlpool MWFW8300SW01 Automatic Washer
Whirlpool MWFW8300SW02 Automatic Washer
Whirlpool MWFW8500SR01 Automatic Washer
Whirlpool MWFW8500SR02 Automatic Washer
Whirlpool MWFW9200SQ00 Automatic Washer
Frigidaire MWL111RBW0 Frg(v1) / 27 " Washer
Frigidaire MWL111RBW1 Frg/27" Washer
Frigidaire MWL111RBW2 Frg(v0) / Washer
Frigidaire MWL411RBD0 Frg(v2) / 27 " Washer
Frigidaire MWL411RBW0 Tap(v7) / 27 " Washer
Frigidaire MWL411RBW1 Frg(v1) / Washer
Frigidaire MWL411RBW2 Tap(v11) / Washer
Frigidaire MWL411RBW3 Tap(v12) / Washer
Frigidaire MWL411RBWD0 Gib(v10) / 27 " Washer
Frigidaire MWL411RBWL0 Frg(v2) / 27 " Washer
Frigidaire MWL411RBWW0 Frg(v1) / 27 " Washer
Amana MWP211 Mwave - Cntrtp / Stand Alone
Amana MWR212 Mwave - Cntrtp / Stand Alone
Amana MWR213 Mwave - Cntrtp / Stand Alone
Amana MWR214 Mwave - Cntrtp / Stand Alone
Amana MWR365 Mwave - Cntrtp / Stand Alone
Amana MWR36510 Mwave - Mounted Over Range/wo
Frigidaire MWS445RES0 Frg(v1) / Washer
Frigidaire MWS445RES1 Frg(v0) / Washer
Frigidaire MWS445RES2 Frg(v0) / Washer
Frigidaire MWS445RET0 Frg(v2) / Washer
Frigidaire MWS445RFS0 Frg(v0) / Washer
Frigidaire MWS445RFS1
Frigidaire MWS445RFS2 Frg(v0) / Washer
Uni MWS833AS2 Universal/washer
Amana MWT344/1001 Mwave - Family Size (60 Hz)
Amana MWT366/1001 Mwave - Family Size (60 Hz)
Amana MWT4441D Mwave - Mounted Over Range/wo
Amana MWT4451D Mwave - Mounted Over Range/wo
Amana MWT4451D01 Mwave - Family Size (60 Hz)
Amana MWT4451WW Mwave - Mounted Over Range/wo
Maytag MWT4451WW  Mwave - Mounted Over Range/wo
Amana MWT4451WW01 Mwave - Family Size (60 Hz)
Amana MWT4461D Mwave - Mounted Over Range/wo
Amana MWT4461WW Mwave - Mounted Over Range/wo
Amana MWT4661D Mwave - Mounted Over Range/wo
Amana MWT4661W Mwave - Mounted Over Range/wo
Amana MWT4661WW Mwave - Mounted Over Range/wo
Frigidaire MWX111REW0 Frg(v0) / Washer
Frigidaire MWX111REW1 Frg(v0) / Washer
Frigidaire MWX111REW2 Frg(v0) / Washer
Frigidaire MWX111REW3 Frg(v0) / Washer
Frigidaire MWX121RBD0 Frg(v2) / 27 " Washer
Frigidaire MWX121RBD2 Frg(v1) / Washer
Frigidaire MWX121RBD3 Frg(v1) / Washer
Frigidaire MWX121RBW0 Tap(v7) / 27 " Washer
Frigidaire MWX121RBW1 Frg/27" Washer
Frigidaire MWX121RBW2 Frg(v2) / Washer
Frigidaire MWX121RBW3 Frg(v2) / Washer
Frigidaire MWX121RBWD0 Kel(v10) / 27 " Washer
Frigidaire MWX121RBWL0 Frg(v2) / 27 " Washer
Frigidaire MWX121RBWW0 Frg(v1) / 27 " Washer
Frigidaire MWX121REW0 Frg(v0) / Washer
Frigidaire MWX121REW1 Frg(v0) / Washer
Frigidaire MWX121REW2 Frg(v0) / Washer
Frigidaire MWX121REW3 Frg(v0) / Washer
Uni MWX121REW4 Washer - Universal
Frigidaire MWX223RED0 Frg(v1) / Washer
  #2 (permalink)
Old 02-24-2009, 06:55 AM
Member
Default
Edit:
I would add the fuse before the noise filter just in case it malfunctions.
Can someone tell me if the noise filter is necessary? I was thinking about eliminating it.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Emerson Microwave just went dead calico51 Microwave Repair 3 09-17-2009 02:30 AM
Emerson microwave nvogen Microwave Repair 0 06-21-2009 01:39 PM
Emerson microwave blows fuse lk2101 Microwave Repair 2 05-05-2009 06:17 AM
Emerson Microwave keeps blowing the fuse rensminger Microwave Repair 1 03-03-2008 03:59 PM
