Appliance Repair Forum
-   Microwave Repair (http://forum.appliancepartspros.com/microwave-repair/)
-   -   possible magnetron failure ? (http://forum.appliancepartspros.com/microwave-repair/24310-possible-magnetron-failure.html)
kap43 02-22-2009 02:34 PM
Micro. quit heating , observed lite smoke comeing from connector on magnetron. Also put volt meter on connector comeing from transformer and read 3.2 volts a.c. is that rite. thanks
fellicianot1 02-22-2009 02:54 PM
Is This Something Commun
kap43 02-22-2009 05:57 PM
i don't know , thats the problem i'm haveing
richappy 02-23-2009 04:35 AM
Seems like your high voltage transformer is not getting any voltage. Usually they will hum if getting voltage. Also, meter readings may be very innacurate near this transformer if drawing current.
You should check for missing voltage from the pc board. Sometimes re soldering the connections to this relay will fix it.
kap43 02-23-2009 02:55 PM
hi thanks. i nuplugged the connector from trans. going to the magnetron and turned the micro. on and took voltage reading at the conn. comeing from trans.
