oven makes a constant noise from the upper right corner of the unit. Noise is louder inside with door open. It sounds like an old electric clock with dry gears and motor. when the power (unplugged) is shut off it stops until the microwave is used again then the noise returns. Everything works just fine just has this fairly loud noise.
