Discuss
turntable not working, everything else is good
 in
Microwave Repair
my turntable stopped working all of a sudden. had 21v to the motor so i assumed a bad motor(i
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » turntable not working, everything else is good
  #1 (permalink)
Old 11-09-2007, 02:05 PM
mcary mcary is offline
Junior Member
mcary is on a distinguished road
Default turntable not working, everything else is good
Model Number: jvm1860wd002   Brand: GE   Age: 1 - 5 years
my turntable stopped working all of a sudden. had 21v to the motor so i assumed a bad motor(i could watch voltage come and go as i run micro and toggled the turntable button on/off). replaced motor and have the same result no movement. any help suggestions would be helpful
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-09-2007, 03:45 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi mcary
Did you check the coupler?
The coupler
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 11-09-2007, 06:13 PM
Junior Member
Default
the coupler is in good shape. could it be a wiring problem or a interlock problem? when the turntable button is depressed the on/off changes on the display so it appears to be working from the keypad.or i could have purchased a bad motor-seems unlikely although i bought it from an appliance place on ****.
  #4 (permalink)
Old 11-09-2007, 06:31 PM
Junior Member
Default
just rechecked it again- when i start the micro i see the voltage at the motor go to approx 35vac on a digital volt meter then quickly drop to 11 vac. the motor sort of vibrates like it is trying to rotate but never does. this is the case with both the old and new motors. is this 11 v enough to drive the motor and where does this voltage come from?
  #5 (permalink)
Old 11-09-2007, 07:31 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
It suppose to be the wiring diagram inside the control panel or behind the top grill on the left side.
11V definitely is not enough for the motor which needs 21V. Also **** is not the best place to by any appliance parts.
If you will find the wiring diagram, post it and I may help you.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven not working-Stovetop working Jame Oven Repair (including Ranges and Cooktops) 8 10-08-2008 10:08 AM
turntable not working, everything else is good mcary Microwave Repair 0 11-09-2007 02:02 PM
Microwave turntable turns erratically mrnester@charter.net Microwave Repair 0 10-23-2007 05:17 PM
Heat but not drying, seems like heat is not blowing good Papa1 Dryer Repair 2 10-07-2007 11:11 AM
Good or Bad HV diode Chuck Sancinito Microwave Repair 2 07-28-2007 12:30 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
