Discuss
microwave wont heat
 in
Microwave Repair
I replaced the door latch, and now everything seems to work ok except it wont heat. Could the door not
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » microwave wont heat
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 11-07-2007, 09:53 AM
chrispeach chrispeach is offline
Junior Member
chrispeach is on a distinguished road
Default microwave wont heat
Model Number: TMH14XMT0   Brand: Estate   Age: 1 - 5 years
I replaced the door latch, and now everything seems to work ok except it wont heat. Could the door not be sealing or something
Any suggestions would be helpful
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-07-2007, 10:49 AM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi chrispeach
Unplug the microwave, open the control panel and make sure the door switches (#10, #23 and #24 on the interior break down diagram) are properly engaged when the door closed. If not then adjust the interlocks or the door latch.
Also check the door switches them self. With the door closed the primary and the secondary interlock switches must be closed and the monitor switch must be open. If the reading is incorrect, replace the wrong switch.
- The part number for the interlock (they are identical) AP3779117
- The part number for the upper switch (#10 on the diagram) AP3918718
- The part number for the inner bottom switch (#23 on the diagram) AP3885662
- The part number for the outer bottom switch (#24 on the diagram) AP3890405
- Here are the break down diagrams for the Estate microwave Model TMH14XMT0
Good luck.
__________________
Professional appliance repair services in Orange County, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer wont heat retcsgt Dryer Repair 0 10-29-2007 03:51 AM
Dryer wont heat TomK Dryer Repair 0 10-27-2007 11:47 PM
Dryer wont heat mike54487 Dryer Repair 1 10-09-2007 02:40 AM
Dryer burner goes out,wont heat MFKLVN Dryer Repair 3 09-24-2007 06:27 PM
dryer wont heat tom46151 Dryer Repair 1 09-10-2007 05:56 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
