Discuss
Microwave Maytag
 in
Microwave Repair
The key board on my microwave has started to not match the pressed fuctions. When I press cancell the fan
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Microwave Maytag
  #1 (permalink)
Old 01-23-2009, 07:12 AM
Junior Member
george6848 is on a distinguished road
Default Microwave Maytag
Model Number: MMV5000BAC   Brand: Maytag   Age: 5 - 10 years
The key board on my microwave has started to not match the pressed fuctions. When I press cancell the fan comes on. The numbers pressed dont show correct.
I tried to unplug for one hour and no help. The keys seem to have a mind of their own.
Is it the control board? What part do I need? I'm a HVAC tech so I know about repairs, but weak on microwaves.
Will need guidance on removal of board/key board cover.
Thanks,
Cris
Related Models
Maytag MMV5000BAC MWAVE- MOUNTED UNDER CABINET
Maytag MMV5000BAQ MWAVE- MOUNTED UNDER CABINET
Maytag MMV5000BAW MWAVE- MOUNTED UNDER CABINET
Maytag MMV5000BDB MWAVE- MOUNTED UNDER CABINET
Maytag MMV5000BDC MWAVE- MOUNTED UNDER CABINET
Maytag MMV5000BDQ MWAVE- MOUNTED UNDER CABINET
Maytag MMV5000BDW MWAVE- MOUNTED UNDER CABINET
Maytag MMV5100AAB MWAVE- MOUNTED UNDER CABINET
Maytag MMV5100AAQ MWAVE- MOUNTED UNDER CABINET
Maytag MMV5100AAS MWAVE- MOUNTED UNDER CABINET
Maytag MMV5100AAW MWAVE- MOUNTED UNDER CABINET
Maytag MMV5156AAB MWAVE- MOUNTED UNDER CABINET
Maytag MMV5156AAQ MWAVE- MOUNTED UNDER CABINET
Maytag MMV5156AAS MWAVE- MOUNTED UNDER CABINET
Maytag MMV5156AAW MWAVE- MOUNTED UNDER CABINET
Maytag MMV5156ACB MWAVE- MOUNTED UNDER CABINET
Maytag MMV5156ACQ MWAVE- MOUNTED UNDER CABINET
Maytag MMV5156ACS MWAVE- MOUNTED UNDER CABINET
Maytag MMV5156ACW MWAVE- MOUNTED UNDER CABINET
Maytag MMV5165AAB MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5165AAQ MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5165AAS MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5165AAW MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5165BAB MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5165BAB14 Microwave Oven/Hood 1.6 Cu. Ft.
Maytag MMV5165BAB15 MICROWAVE OVEN/HOOD 1.6 Cu. Ft.
Maytag MMV5165BAS MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5165BAS14 Microwave Oven/Hood 1.6 Cu. Ft.
Maytag MMV5165BAS15 MICROWAVE OVEN/HOOD 1.6 Cu. Ft.
Maytag MMV5165BAW MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5165BAW15 Microwave Oven/Hood 1.6 Cu. Ft.
Maytag MMV5165BAW16 MICROWAVE OVEN/HOOD 1.6 Cu. Ft.
Maytag MMV5186AAB MWAVE- MOUNTED UNDER CABINET
Maytag MMV5186AAQ MWAVE- MOUNTED UNDER CABINET
Maytag MMV5186AAS MWAVE- MOUNTED UNDER CABINET
Maytag MMV5186AAW MWAVE- MOUNTED UNDER CABINET
Maytag MMV5186ACB MWAVE- MOUNTED UNDER CABINET
Maytag MMV5186ACQ MWAVE- MOUNTED UNDER CABINET
Maytag MMV5186ACS MWAVE- MOUNTED UNDER CABINET
Maytag MMV5186ACW MWAVE- MOUNTED UNDER CABINET
Maytag MMV5201DB00 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag MMV5201DS00 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag MMV5201DW00 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag MMV5207AAB MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207AAQ MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207AAS MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207AAW MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207ACB MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207ACQ MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207ACS MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207ACW MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207BAB MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207BAB14 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BAB17 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag MMV5207BAQ MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207BAQ14 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BAQ17 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag MMV5207BAS MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207BAS14 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BAS17 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag MMV5207BAW MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207BAW15 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BAW18 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag MMV5207BCB MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207BCB14 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BCB17 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BCB18 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BCQ MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207BCQ14 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BCQ17 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BCQ18 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BCS MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207BCS14 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BCS17 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BCS18 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BCW MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207BCW15 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BCW18 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BCW19 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5208WB0 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Maytag MMV5208WQ0 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Maytag MMV5208WS0 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Maytag MMV5208WW0 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Maytag MMV6178AAB MICROWAVE - CONVECTION
Maytag MMV6178AAQ MICROWAVE - CONVECTION
Maytag MMV6178AAS MICROWAVE - CONVECTION
Maytag MMV6178AAW MICROWAVE - CONVECTION
Maytag MMV6180WB0 Microwave Oven/Hood 1.8 Cu. Ft.
Maytag MMV6180WS0 Microwave Oven/Hood 1.8 Cu. Ft.
Maytag MMV6180WW0 Microwave Oven/Hood 1.8 Cu. Ft.
Maytag MMV6186WB0 Microwave Oven/Hood 1.8 Cu. Ft.
Maytag MMV6186WS0 Microwave Oven/Hood 1.8 Cu. Ft.
Maytag MMV6186WW0 Microwave Oven/Hood 1.8 Cu. Ft.
Maytag MMW5527BAB WALLOVEN- S/C ELE
Maytag MMW5527BAW WALLOVEN- S/C ELE
Maytag MMW5527CAB WALLOVEN- S/C ELE
Maytag MMW5527CAW WALLOVEN- S/C ELE
Maytag MMW5530BAB WALLOVEN- S/C ELE
Maytag MMW5530BAW WALLOVEN- S/C ELE
Maytag MMW5530CAB WALLOVEN- S/C ELE
Maytag MMW5530CAW WALLOVEN- S/C ELE
Maytag MMW5530DAB WALLOVEN- S/C MWAVE ELE
Maytag MMW5530DAB20 30" BUILT-IN MICROWAVE/ELECTRIC OVEN COMBO SELF-CLEAN
Maytag MMW5530DAW WALLOVEN- S/C MWAVE ELE
Maytag MMW5530DAW21 30" BUILT-IN MICROWAVE/ELECTRIC OVEN COMBO SELF-CLEAN
Maytag MMW7530WDB01 30" BUILT-IN ELECTRIC COMBO SENSOR/SC
Maytag MMW7530WDS01 30" BUILT-IN ELECTRIC COMBO SENSOR/SC
Maytag MMW7530WDW01 30" BUILT-IN ELECTRIC COMBO SENSOR/SC
Norge MN15E-5 MWAVE- CNTRTP / STAND ALONE
Norge MN15F-14T MWAVE- CNTRTP / STAND ALONE
Norge MN15FN-14T MWAVE- CNTRTP / STAND ALONE
Norge MN46G-14T MWAVE- CNTRTP / STAND ALONE
Norge MN46GN-14T MWAVE- CNTRTP / STAND ALONE
 MO1450BA MWAVE- MOUNTED OVER RANGE/WO
 MO1450CA MWAVE- MOUNTED OVER RANGE/WO
 MO1450WA MWAVE- MOUNTED OVER RANGE/WO
 MO1650BA MWAVE- MOUNTED OVER RANGE/WO
 MO1650CA MWAVE- MOUNTED OVER RANGE/WO
 MO1650WA MWAVE- MOUNTED OVER RANGE/WO
Magic Chef MOD61AD MWAVE- MOUNTED OVER RANGE/WO
  #2 (permalink)
Old 01-23-2009, 12:22 PM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
Sounds like your control board is messed up. Might be worthwhile to have a pro check to see if there is any internal microwave leakage. This can really play havoc on the electronics.
  #3 (permalink)
Old 01-26-2009, 07:50 AM
Junior Member
Default
Can anyone help me?
  #4 (permalink)
Old 01-27-2009, 12:41 PM
Junior Member
iamatke is on a distinguished road
Default
To be blunt, the keypads on those maytag ovens "suck". What you can try is to remove the control pad and check the connection from the keypad to the control card. Remove the two screws securing the top grill then fold down and out. Remove the one screw securing the wiring cover grill and one from the control panel. The panel will then slide out and up. The keypad is attached with a flex circuit. The tabs on the connector pull up to remove the cable. You can use a mild detergent but you don't want to remove any coatings. Firmly reseat the cable and slide the tabs down to secure it. This MAY help, but in all likelyhood you probably need to replace the keypad. You can order the part through this site, make sure you specify white or black because it comes with the cover.
  #5 (permalink)
Old 01-28-2009, 06:29 AM
Junior Member
Default
Thanks for the help, I'm a HVAC tech, don't know much about microwaves.
If you need any HVAC support let me know.
Cris
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
maytag microwave fieldhockeychamps Oven Repair (including Ranges and Cooktops) 0 12-21-2009 07:17 PM
maytag microwave won't heat up dick2256@hotmail.com Microwave Repair 2 10-04-2009 11:15 AM
maytag microwave scott g48 Microwave Repair 1 08-24-2009 03:14 PM
Maytag Microwave mounting help inshortorder Microwave Repair 0 01-31-2009 09:10 AM
Maytag microwave dead WarMar Microwave Repair 3 01-08-2009 03:30 PM
