| » Microwave turntable not turning |
Model Number: mmv5100aaw Brand: Maytag Age: 5 - 10 years
Is the problem more likely to be in the turntable motor or is there a switch that could be burned out ? How difficult is motor or switch replacement ?
Quote:
The turntale motor could be the problem, Part number: AP4063781 But it's most likely a bad relay on the control board, Part number: AP330204 To access the turntable motor: 1) Turn the microwave on it's back (you may be able to and avoid this step). 2) Remove the 3 screws securing the bottom plate to the oven cavity. 3) Disconnect the wires from the turntable motor and the lamp. Once you get access to the turntable motor, you can check for voltage from the relay by inserting the meter probes in the wire connectors, and start a short cook cycle and check, no voltage= bad relay or broken wire, have voltage= bad turntable motor. Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Microwave turntable not turning | raggediean | Microwave Repair | 1 | 01-11-2011 07:37 PM |
| GE Microwave Turntable not turning | Lauri Leaverton | Microwave Repair | 0 | 04-17-2010 12:35 PM |
| Frigidaire Microwave Turntable not turning! | StefGal | Microwave Repair | 0 | 08-26-2009 06:59 AM |
| MAYTAG Microwave Turntable stop turning | JeanJean | Microwave Repair | 0 | 05-07-2009 08:58 AM |
| Brand new Microwave Turntable not turning | trimbojd | Microwave Repair | 1 | 05-04-2009 02:33 PM |
