chaya
#1 Posted : Wednesday, April 13, 2011 7:34:07 AM(UTC)
chaya
how do i replace the ceramic tray?
Joe / APP Team
#2 Posted : Thursday, April 14, 2011 8:05:31 AM(UTC)
Joe / APP Team
Chaya,
I reccomend a putty knife and a razor blade or "exacto" knife, a small tube of white silicone sealer/adhesive.
You need to be careful with the razor and putty knife. Don't scratch the paint on the cavity walls.
With the razor carefully trim around the edge of the ceramic tray and walls, and across the front opening where the bottom of the tray meets the base of the cavity. Use the putty knife to separate the tray from the base of the cavity.
With the silicone sealer, put a 1/4 in. bead around the base of the cavity, and across the front edge, Press the tray firmly into the sealant, clean out any residual sealer that squeezes up between the wall and tray, make sure there is no voids in the sealer and allow to dry(per the sealant reccomendations).
Thanks,
Good Luck,
GE Oven - Microwave/Oven PT7800SH2SSA (Oven Repair (including Ranges and Cooktops))
by Guest 2/13/2024 11:22:12 AM(UTC)
Kenmore Pizza Oven Microwave (Microwave Repair)
by mwjkmail 2/3/2024 5:10:49 PM(UTC)
Kitchenaid (Whirlpool) Microwave door switches (Microwave Repair)
by ForumUser1 1/11/2024 1:11:07 PM(UTC)
Whirlpool Microwave Lower Bulb will not turn on (WMH31017HS08) (Microwave Repair)
by Axtell 1/2/2024 3:49:44 PM(UTC)
Kitchen aid electric wall microwave and oven (Microwave Repair)
by Guest 11/9/2023 8:15:09 AM(UTC)
Frigidaire Microwave PLMVZ169HCA (Microwave Repair)
by Guest 10/25/2023 11:02:01 AM(UTC)
KitcheAid Microwave/Oven Wall Combo KOCE500ESS05 Error Code F6E8 (Microwave Repair)
by tjperlman 10/19/2023 10:07:59 PM(UTC)
Microwave Advantium 120 display blank (Microwave Repair)
by tod.colbert@gmail.com 8/6/2023 9:13:49 AM(UTC)
Litton model 1800 microwave (Microwave Repair)
by Guest 7/14/2023 7:08:12 PM(UTC)
Microwave touchpad (Microwave Repair)
by duguyisheng 7/6/2023 5:12:28 PM(UTC)
Over range Microwave exhaust fan slows (Microwave Repair)
by Mmetzinger 6/3/2023 7:19:23 AM(UTC)
Dim Light on Microwave (Microwave Repair)
by Guest 5/15/2023 8:31:44 AM(UTC)
Kitchenaid kbms1454bbl microwave (Microwave Repair)
by Guest 4/1/2023 10:24:42 AM(UTC)
Microwave Parts Cannot Be Returned and Microwave Still Has The Problem (Microwave Repair)
by atlantic 3/31/2023 12:42:43 PM(UTC)
Apollo convection microwave (Microwave Repair)
by Guest 2/21/2023 12:14:33 PM(UTC)
