Discuss
Gene: need advice on Amana ACO 1860 AW: not heating
 in
Microwave Repair
Gene, Please....I need your help. (Amana ACO 1860 AW 6 yrs old) I fault traced everything, & everything specked
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Gene: need advice on Amana ACO 1860 AW: not heating
  #1 (permalink)
Old 01-05-2009, 11:51 AM
eyefish eyefish is offline
Junior Member
eyefish is on a distinguished road
Default Gene: need advice on Amana ACO 1860 AW: not heating
Model Number: ACO 1860 AW   Brand: Amana   Age: 5 - 10 years
Gene,
I fault traced everything, & everything specked out OK.
All values of all the pertinent parts were within spec. (as per service manual, & tech sheet behind control panel.
I replaced the diode, because I got a false negative on the original one, but the new one tests the same as the old one. (I rechecked them both with a 10V battery later, & instead of testing with an OHM meter...I checked current flow one way & the other....current flowed one way, but not the other)
So now my question is: some unknown part needs replacement...should I just replace the magnetron; even though it tests fine using the test procedures of the service manual & spec sheet?
It's an expensive part to buy if that isn't the problem for certain.
Please advise ASAP.
Thanks,
Al
Related Models
Amana ACO1180AB Rv Microwave
Amana ACO1180AC Rv Microwave
Amana ACO1180AS Rv Microwave
Amana ACO1180AW Rv Microwave
Amana ACO1520AB Mwave - Mounted Over Range/wo
Amana ACO1520AC Mwave - Mounted Over Range/wo
Amana ACO1520AW Mwave - Mounted Over Range/wo
Amana ACO1560AB Frigidaire/range
Amana ACO1560AC Mwave - Mounted Under Cabinet
Amana ACO1560AS Mwave - Mounted Under Cabinet
Amana ACO1560AW Mwave - Mounted Under Cabinet
Amana ACO1840AB Mwave - Mounted Over Range/wo
Amana ACO1840AC Mwave - Mounted Over Range/wo
Amana ACO1840AW Mwave - Mounted Over Range/wo
Amana ACO1860AB Mwave - Mounted Over Range/wo
Amana ACO1860AC Mwave - Mounted Over Range/wo
Amana ACO1860AS Mwave - Mounted Over Range/wo
Amana ACO1860AW Mwave - Mounted Over Range/wo
Amana ACO27DE Walloven - Std Ele
Amana ACO27DE1 Walloven - Std Ele
Amana ACO27DEW Walloven - Std Ele
Amana ACO27DEW1 Walloven - Std Ele
Amana ACO27DK Walloven - Std Ele
Amana ACO27SE Walloven - Std Ele
Amana ACO27SE1 Walloven - Std Ele
Amana ACO27SEW Walloven - Std Ele
Amana ACO27SEW1 Walloven - Std Ele
Amana ACO27SK Walloven - Std Ele
Frigidaire ACO59J7B1 Wwh(v2) / Room Air Conditioner
Whirlpool ACP052XM0
Whirlpool ACP052XM1
Whirlpool ACP052XT0
Whirlpool ACP062XM0
Whirlpool ACP062XM1
Whirlpool ACP092PR0 Portable Air Conditioner
Whirlpool ACP102PR0 Portable Air Conditioner
Whirlpool ACP102PR1 Portable Air Conditioner
Whirlpool ACP102PR2 Portable Air Conditioner
Whirlpool ACP102PR3 Portable Air Conditioner
Whirlpool ACP102PS0 Portable Air Conditioner
Whirlpool ACP102PS2 Portable Air Conditioner
Amana ACP11 Freezer - Chest
Whirlpool ACP492XM0
Whirlpool ACP492XM1
Whirlpool ACP492XT0
Whirlpool ACP502XM0
Whirlpool ACP502XM1
Whirlpool ACP502XR0
Whirlpool ACP552XR0
Whirlpool ACP552XS0
Whirlpool ACP552XT0
Whirlpool ACP552XT1
Whirlpool ACP602XM0
Whirlpool ACP602XP0
Whirlpool ACP602XS0
Whirlpool ACP602XT0
Whirlpool ACP802XM0
Whirlpool ACP802XP0
Whirlpool ACPE102PS0 Portable Air Conditioner Heat/cool
Whirlpool ACPE102PS2 Portable Air Conditioner Heat/cool
Whirlpool ACPS82XS0
Whirlpool ACQ052PK0
Whirlpool ACQ052PP0 Air Conditioner
Whirlpool ACQ052PR0 Air Conditioner
Whirlpool ACQ052PR1 Air Conditioner
Whirlpool ACQ052PR2 Air Conditioner
Whirlpool ACQ052PR3 Air Conditioner
Whirlpool ACQ052PS0 Air Conditioner
Whirlpool ACQ052PS1 Air Conditioner
Whirlpool ACQ052PS2 Air Conditioner
Whirlpool ACQ052PS3 Air Conditioner
Whirlpool ACQ052XA0
Whirlpool ACQ052XD0
Whirlpool ACQ052XF0
Whirlpool ACQ052XG0
Whirlpool ACQ052XG1
Whirlpool ACQ052XH0
Whirlpool ACQ052XJ0
Whirlpool ACQ052XW0
Whirlpool ACQ052XY0
Whirlpool ACQ052XZ0
Whirlpool ACQ052XZ1
Whirlpool ACQ052XZ2
Whirlpool ACQ058MM0 Air Conditioner
Whirlpool ACQ058PL0 Air Conditioner
Whirlpool ACQ058PL1 Air Conditioner
Whirlpool ACQ058PP0 Air Conditioner
Whirlpool ACQ058PR0 Air Conditioner
Whirlpool ACQ058PR1 Air Conditioner
Whirlpool ACQ058PR2 Air Conditioner
Whirlpool ACQ058PR3 Air Conditioner
Whirlpool ACQ058PS0 Air Conditioner
Whirlpool ACQ058PS1 Air Conditioner
Whirlpool ACQ058PS2 Air Conditioner
Whirlpool ACQ058PS3 Air Conditioner
Whirlpool ACQ058PS4 Air Conditioner
Whirlpool ACQ058PS5 Air Conditioner
Whirlpool ACQ058PS6 Air Conditioner
Whirlpool ACQ058PS7 Air Conditioner
Whirlpool ACQ062MM0 Air Conditioner
Whirlpool ACQ062MP0 Air Conditioner
Whirlpool ACQ062MP1 Air Conditioner
Whirlpool ACQ062PK0
  #2 (permalink)
Old 01-06-2009, 05:14 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
Answered here: Microwave: no heat - GENE: HV Diode Dead (was Amana ACO1860AW not heating)
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Amana convection not heating Mvantilburg Oven Repair (including Ranges and Cooktops) 30 09-02-2009 07:34 PM
Microwave: no heat - GENE: HV Diode Dead (was Amana ACO1860AW not heating) eyefish Microwave Repair 6 01-09-2009 02:37 PM
GENE: HV Diode Dead (was Amana ACO1860AW not heating) eyefish Microwave Repair 0 01-03-2009 02:38 PM
Amana Over-the-Range not heating eyefish Microwave Repair 0 01-02-2009 02:45 PM
Amana Dryer Not Heating TKERBERNC Dryer Repair 1 03-22-2008 08:00 PM
