Okay I took the door off.
I got the inside surrounding plastic fram off....broke a few tabs.
The screw for the bottom of the handle is accessible.
The top screw is behind the steel door (at the corner)...the door itself piece with the glass in it. There are 6 screws around it which I removed but the door is still solid. no movement.
How do I get access to that top door handle screw?
Thanks to anyone who reponds.
Mike
