| » Turntable motor |
Model Number: JE1590WH02 Brand: GE Age: 1 - 5 years
Please furnish step by step instructions on removing and replacing the turntable motor and adapter that sits under the glass turntable plate...
Please also furnish your item/part numbers for both the turntable motor and the three sided "D" shaft adapter Turntable is lurching and making a grinding noise but is still turning Thanks much in advance Ads By Google Related Models |
Quote:
Here are the part numbers you requested, Part number: AP2632784 Part number: AP3791385 And here's a general repalcement procedure, (there's not much information) Disconnect the power cord, or power to the unit. Remove the turntable plate, and carriage(if equipped) and drive coupling from cavity. Turntable Motor Removal Remove screws from the bottom of the microwave oven cabinet and remove the bottom plate. Remove the screw, then rotate the motor CCW 1/ 8 turn. Remove the turntable motor. Disconnect 2 wires from the motor. Reverse procedure and test unit. We hope this helps, Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Quote:
I had the same problem, we did the best we could, the information should be able to get you through the repair. It's always a pleasure to assist our customers. You have a good day as well, and thanks for contacting Appliance Parts Pros Repair Forum.
__________________
| Display Modes | |
| FRIGIDAIRE Turntable motor | justmiracle | Microwave Repair | 0 | 12-14-2010 06:41 AM |
| Turntable Motor (drive vs. stirrer) | PoggiPJ | Microwave Repair | 7 | 07-02-2009 10:37 PM |
| How to replace turntable Motor | pegsue62 | Microwave Repair | 0 | 01-10-2009 12:35 PM |
| GE microwave turntable motor | verndewitt | Microwave Repair | 1 | 10-20-2008 02:51 PM |
| How do I connect wires to turntable motor? | ltml82 | Microwave Repair | 1 | 02-20-2008 04:37 PM |
