Appliance Repair Forum
-   Microwave Repair (http://forum.appliancepartspros.com/microwave-repair/)
-   -   KA/Whirlpool Micro/Hood F2 Control Panel Error (http://forum.appliancepartspros.com/microwave-repair/193252-ka-whirlpool-micro-hood-f2-control-panel-error.html)
abby-grace 03-25-2011 06:59 AM
This micro/hood started beeping uncontrollably. It gives an F2 code. The internet clearly states that this is a defect that is happening with many of the Whirlpool/KitchenAid models. The control pad will also lock up. We used to be able to unplug it and it would reset but that no longer works. As I stated, this seems to be a common problem and some people even have theirs turn on without them doing it--we are not there yet.
My question is: do we need to order a new control panel and/or a micro computer? Thanks!
Joe / APP Team 03-25-2011 08:58 AM
Quote:
Originally Posted by abby-grace (Post 387738)
This micro/hood started beeping uncontrollably. It gives an F2 code. The internet clearly states that this is a defect that is happening with many of the Whirlpool/KitchenAid models. The control pad will also lock up.We used to be able to unplug it and it would reset but that no longer works. As I stated, this seems to be a common problem and some people even have theirs turn on without them doing it--we are not there yet.
Abby-grace,
The F2 code, for your unit indicates you have a faulty touchpad assembly.
Part number: AP4512484
For future referrence,
Most touchpad failures on a over the range microwave ovens are due to usage, and heat,steam, etc. coming off the range cooktop, You may find that turning on the vent fan when cooking on the stove may help to extend the life of your keypad assembly.
Good Luck,
abby-grace 03-25-2011 09:57 AM
Thanks! Makes total sense too because all the stainless steel coating wore off the handle because of the heat and steam from the stove burner below. THANKS AGAIN!
Joe / APP Team 03-25-2011 03:02 PM
Quote:
Abby-grace,
It was our pleasure to assist you.
If you need help in the future, please contact us.
Thank You,
Good Luck,
