Appliance Repair Forum
Appliance Repair Forum (
-   Microwave Repair (
-   -   Tappan Microwave (
tragan1 01-01-2009 03:59 PM
Tappan Microwave
My Tappan microwave will lose power and shut off like we had a power outage, everytime I try to heat something, and the clock, fan, lights, all works except for the power setting button, I can press reset, and repeat it, I also tried to reset the clock, but that didn't help either. The unit is 2 years old. Does anyone have any ideas. Does this sound like a bad transformer?
Thanks, Tim
Gene 01-02-2009 01:59 PM
Hi Tim,
I'm afraid I did not get it clear. You closed the door, set the cooking time and pushed the Start button - what happened after?
tragan1 01-02-2009 02:10 PM
Hi Gene,
Thanks for the response. Sorry I might not have been clear. I close the door, set cook time, push the start button, it will run for maybe 3-4 seconds and shut off like the electric went off, the display will come back on to 00:00 and then show this on the display :0, I then can push clear a couple times, reset the clock and do it all again.
Gene 01-02-2009 02:40 PM
Sounds like there are leakage of Electromagnetic waves from the magnetron, interfering with the control board. The correction of such problem is replacing the magnetron.
- The part number for the magnetron is AP3960618
Here are the break down diagrams for the Tappan microwave Model TMV151FBA
