Discuss
Microwave does not heat.
 in
Microwave Repair
Everything works.Just does not heat up.Had the same thing happen 2 years ago and I just replaced it
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Microwave does not heat.
  #1 (permalink)
Old 10-22-2007, 10:26 PM
35mastr 35mastr is offline
Junior Member
35mastr is on a distinguished road
Default Microwave does not heat.
Model Number: 721.80802400   Brand: Kenmore   Age: Less than 1 year
Everything works.Just does not heat up.Had the same thing happen 2 years ago and I just replaced it with this one.Please chime in with any and all troubleshooting advice.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-24-2007, 09:24 AM
Junior Member
Default
Bump
Has anyone ever run into this problem??
__________________
George
  #3 (permalink)
Old 10-24-2007, 11:02 AM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi George
Does it make any unusual noises? If it does try to describe it.
__________________
Professional appliance repair in Los Angeles, California.
  #4 (permalink)
Old 10-24-2007, 07:31 PM
Junior Member
Default
Gene,It works just like it did when I pulled it out of the box when new.No abnormal noises or anything unusual.It just does not heat any thing up.Not even warm.All displays work,Lights inside Etc.Just will not heat anything up.
__________________
George
  #5 (permalink)
Old 10-24-2007, 07:51 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Sounds like the magnetron tube is bad. Do not touch anything and call Sears. The microwave is less then a year old and is under the warranty.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Microwave Does Not Heat. jpeterman12 Microwave Repair 2 03-22-2008 08:37 AM
microwave does not heat all else is ok geo Microwave Repair 20 12-19-2007 07:31 AM
Microwave does not heat hattesn Microwave Repair 0 10-06-2007 12:09 PM
Microwave will not heat billr Microwave Repair 0 09-06-2007 05:04 PM
microwave dont heat Ruben Lucero Microwave Repair 0 09-01-2007 03:24 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
