My microwave does not heat, everything else works fine but it does not heat. I have tested the Magnetron, Transformer, Capacitor and Diode. Only the diode tests bad, My question is, is a blown diode caused by something else wrong in the HV system or is it normal for the diode to fail on it's own ? :confused:
