Was manufactured April of 2009 so I ay have had a little over a yr now. Open the door to get something out and it kept running. Would only shut off when I closed the door. Tried unplugging and replugging maybe to reset? cycle? and it still does the same. I have read something about ddor swithch. but this unit has 2 door latches that are buried in unit and barely stick out to catch door. I dont see any dirt or grease on them. Is the swithc buried back in the unit and if so how did it get that much dirt, etc in such little time. Never had one do this. Is this inherent to GE?
Thanks, Pat
