| » microwave glass in door |
Remove the choke screws at the end of the door. You can take a flat blade screwdriver or butter knife, and carefully pry out the inner door seal. This is made of plastic so be careful not to break it. Once inside, you should be able to remove the painted glass assembly. Remove it and proceed to the the front glass. Hope this helps.
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Jeff K. / APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. Last edited by Jeff / APP Team : 02-18-2011 at 12:58 PM. |
Yes you can just replace the glass, not the whole door. If you need the glass, here is the part number, along with a link to the parts diagram. Hope this helps.Part number: AP3205414
Microwave replacement parts for General Electric JE2160SF03 Counter top microwave | AppliancePartsPros.com
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Jeff K. / APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Some of the doors do not use choke screws. The inner part has clips around the inside that holds it in. Release those clips and lift it out. Hope this helps.
__________________
| Display Modes | |
| microwave door glass shattered | snilakhe | Microwave Repair | 1 | 01-10-2011 05:18 AM |
| Replace Microwave Outer Door Glass Panel | ahovde | Microwave Repair | 0 | 11-01-2010 07:22 PM |
| stained glass on microwave door | rideblackgeym | Microwave Repair | 0 | 01-29-2010 11:44 AM |
| Microwave Door Glass Replacement | Johne. | Microwave Repair | 1 | 07-13-2009 03:35 AM |
| glass for microwave door | Gonzalo Silva | Microwave Repair | 1 | 03-18-2009 07:19 PM |
