Discuss
Advantium F3 Error
 in
Microwave Repair
Our Advantium is giving an F3 error code and beeping repeatedly. I believe this is a keypad error and the
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Advantium F3 Error
  #1 (permalink)
Old 10-17-2007, 09:09 AM
t-bone t-bone is offline
Junior Member
t-bone is on a distinguished road
Default Advantium F3 Error
Model Number: scb2001kss02   Brand: GE   Age: 1 - 5 years
Our Advantium is giving an F3 error code and beeping repeatedly. I believe this is a keypad error and the keypad doesn't respond to most buttons now. I'm unable to find a schematic for this particular model and I'm not sure specifically what part(s) need to be replaced on the keypad.
Related Models
General Electric SCB2001KSS02 Counter top microwave
General Electric SCBC2000CBB00 Counter top microwave
General Electric SCBC2000CBB001
General Electric SCBC2000CBB01 Counter top microwave
General Electric SCBC2000CCC00 Counter top microwave
General Electric SCBC2000CCC001
General Electric SCBC2000CCC01 Counter top microwave
General Electric SCBC2000CWW00 Counter top microwave
General Electric SCBC2000CWW001
General Electric SCBC2000CWW01 Counter top microwave
General Electric SCBC2001CSS00 Counter top microwave
General Electric SCBC2001CSS001
General Electric SCBC2001CSS01 Counter top microwave
Amana SCD19H Ref - SXS/I&W
Amana SCD19J Ref - SXS/I&W
Amana SCD22J Ref - SXS/I&W
Amana SCD22NL Ref - SXS/I&W
Amana SCD22NW Ref - SXS/I&W
Amana SCD22TBL Ref - SXS/I&W
Amana SCD22TBW Ref - SXS/I&W
Amana SCD23VBL Ref - SXS/I&W
Amana SCD23VBW Ref - SXS/I&W
Amana SCD23VL Ref - SXS/I&W
Amana SCD23VW Ref - SXS/I&W
Amana SCD25J Ref - SXS/I&W
Amana SCD25JB Ref - SXS/I&W
Amana SCD25JP Ref - SXS/I&W
Amana SCD25N2L Ref - SXS/I&W
Amana SCD25N2W Ref - SXS/I&W
Amana SCD25NL Ref - SXS/I&W
Amana SCD25NW Ref - SXS/I&W
Amana SCD25TBL Ref - SXS/I&W
Amana SCD25TBW Ref - SXS/I&W
Amana SCD25TL Ref - SXS/I&W
Amana SCD25TW Ref - SXS/I&W
Thermador SCD272T
Thermador SCD302T
Amana SCDE25J Ref - SXS/I&W
Amana SCDT20H Ref - SXS/I&W
Amana SCDT22H Ref - SXS/I&W
Amana SCDT25H Ref - SXS/I&W
Jenn-Air SCE30500B Range - S/c S/i Ele
Jenn-Air SCE30500W Range - S/c S/i Ele
Jenn-Air SCE30600B Range - S/c S/i Ele
Jenn-Air SCE30600BC Range - S/c S/i Ele
Jenn-Air SCE30600W Range - S/c S/i Ele
Jenn-Air SCE30600WC Range - S/c S/i Ele
Jenn-Air SCE4320B Range - S/c S/i Ele
Jenn-Air SCE4320W Range - S/c S/i Ele
Jenn-Air SCE4340B Range - S/c S/i Ele
Jenn-Air SCE4340B-C Range - S/c S/i Ele
Jenn-Air SCE4340W Range - S/c S/i Ele
Jenn-Air SCE4340W-C Range - S/c S/i Ele
Jenn-Air SCE70600B Range - S/c S/i Ele
Jenn-Air SCE70600W Range - S/c S/i Ele
Whirlpool SCF0710HQ00
Whirlpool SCF0710HQ01
Whirlpool SCF0710HW00
Whirlpool SCF0710HW01
Whirlpool SCF0710HW05
Whirlpool SCF0710KQ00
Whirlpool SCF0710KQ01
Whirlpool SCF0710KQ02 Chest Freezer
Whirlpool SCF0710KQ03 Chest Freezer
Whirlpool SCF0710KQ04 Chest Freezer
Whirlpool SCF1510HW00
Whirlpool SCF1510HW02
Whirlpool SCF1510HW05
Jenn-Air SCG20200A Range - S/c S/i Gas
Jenn-Air SCG20200B Range - S/c S/i Gas
Jenn-Air SCG20200W Range - S/c S/i Gas
Thermador SCM-1
Whirlpool SCS3004GN0
Whirlpool SCS3004GN1
Whirlpool SCS3004GS0
Whirlpool SCS3004GS1
Whirlpool SCS3004GS2
Whirlpool SCS3004GV1
Whirlpool SCS3004GV2
Whirlpool SCS3004GW0
Whirlpool SCS3004GW1
Whirlpool SCS3004GW2
Whirlpool SCS3004LW0
Whirlpool SCS3004LW01 30" Gas Cooktop
Whirlpool SCS3014GB0
Whirlpool SCS3014GB1
Whirlpool SCS3014GB2
Whirlpool SCS3014GB3
Whirlpool SCS3014GQ0
Whirlpool SCS3014GQ1
  #2 (permalink)
Old 10-17-2007, 11:39 AM
Pegi's Avatar
Pegi Pegi is offline
Senior Expert
APP Volunteer
Pegi is on a distinguished road
Default
Here is the breakdown of your unit so you can locate the keypad. CLICK HERE
__________________
-Serving North Central Texas and Southern Oklahoma since 1978.
www.samsservicesenter.com
  #3 (permalink)
Old 10-17-2007, 11:41 AM
Pegi's Avatar
Senior Expert
APP Volunteer
Default
F3 Shorted key panel (touch pad), will occur if a shorted key panel is detected continuously over 60 seconds Replace key panel (touch pad)
__________________
  #4 (permalink)
Old 08-28-2008, 06:49 PM
docrings docrings is offline
Junior Member
docrings is on a distinguished road
Default DIY guide for F3 error and keypad replacement
Thought I'd post a quick DIY guide and let you know this repair of the keyboard only cost me $120 (parts + shipping).
This is based upon my ZSC2001FSS02 wallmount model. Keypad broke in 24 months of use... not bad for a $2500 microwave... not!
0. Order the keypad/chrome trip plate (#68 in the diagram). ~$120 at part select (or wherever else you can get a deal)
1. Turn off breaker to the Advantium oven and remove rotissarie plate/frame from inside oven.
2. position a tall platform with a blanket on it (sawhorses or stools) to set the oven on when you remove it from the wall... it will probably have an armored cable attached to the back that might not be easy to remove... so you'll have to work on it in front of where it was mounted.
3. Open the microwave door... remove the four screws on the sides mounting it to the cabinetry.
4. With help (it's about 120 pounds), slide the oven forward and onto the work space, being wary of it's electrical cord.
5. Remove the screws holding the top panel in place. Remove by tilting the panel backside upwards to disengage the lip on its front side.
6. Now, with a long magnetized philips screwdriver, remove the four screws which hold the front keypad assembly to the oven.
7. Remove the front stainless keypad assembly by sliding it upwards off its pegs which are on either side. (Lift it straight up)
8. Follow the set of black/white wires from the keypad assembly to the main electical board near the back of the oven... disconnect the rectangular plugs from the main board carefully (they have a small latch on them).
9. Remove the stainless keypad assembly with wiring from the unit and place upside down on a padded towel to avoid scratching the old (and the new) stainless keypad assembly.
10. Remove the knob from its post... careful and slow... it's REALLY on there. I was able to use my fingers only...but it was a workout.
11. Remove the three screws holding the rotary knob circuit board from the black plastic base. (This will allow you to remove the black base from the stainless keypad surround.
12. Disconnect the flat ribbon cable by pulling outward on the black plastic sleeve. (You might want to practice re-inserting it... and see how far in it really has to go to bottom out and be firmly inserted.)
13. Remove the screws holding the black base to the stainless keypad surround, and remove the black base... it is held in place by a small metal tab under just to the side of where the rotary knob circuity board was prior to you removing it.
14. Remove the four brackets from the old stainless surround and save for the next step.
15. Now get your new keypad and stainless surround, lay it on the soft towel, and mount the old four brackets to the new piece.
16. Now reverse install everything. Remember, the black plastic base that holds the display will NOT go back into the new part if the knob shaft is installed... that has to be installed AFTER you mount the black plastic base onto the keypad stainless surround.
Reverse everything and then power up. The display should go completely lit (all pixels) for about 15 seconds, and then you set the clock. If you can set the clock... you are good to go.
Good job!!!
Matt's Tech and DIY site for picture DIY tutorial.
  #5 (permalink)
Old 12-13-2008, 06:22 PM
movingaway movingaway is offline
Junior Member
movingaway is on a distinguished road
Default Thanks
Thanks for posting these instructions. You saved us a lot of money. Unfortunately we already had a GE repair man come to the house to look at the unit and order the part ($160 for the part). Luckily they had the part sent directly to our house so following your instructions we just finished installing it ourselves. I'll be glad to call Monday morning and cancel the appointment for the guy to come back and install the part for us, and charge an outrageous labor rate for it. Where did you order the part yourself, if we have this problem again?
Thanks again,
-Jenn
  #6 (permalink)
Old 12-20-2008, 07:22 AM
Junior Member
Default
I used "part select" website , easy payment, quick shipment, and a good return policy (which I have used without troubles).
Here's the direct link to my repair tutuorial with pictures: HERE
Enjoy!
Doc
  #7 (permalink)
Old 10-01-2009, 09:30 AM
winagainjoe winagainjoe is offline
Junior Member
winagainjoe is on a distinguished road
Default
docrings.. can't thank you enough for the step by step insturctions to fix this annoying problem. We too came back from vactation to a beeping and self starting Advantium. With your help, I was able to get it up and running in four days. I went with D&D Appliance Parts instead of your selection. It was about $20 cheaper and just as quick shipping wise. On to the next task! thanks!!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
F1 Error After Self Clean karenhorton Oven Repair (including Ranges and Cooktops) 2 10-26-2007 03:32 PM
GE Advantium Display Blanking Out pgmr Microwave Repair 4 10-21-2007 03:09 AM
Error F1 F7 patsyl44 Oven Repair (including Ranges and Cooktops) 0 09-28-2007 08:14 AM
GE/Advantium 1.2 Cu. Ft. Over The Range Microwave DebnJim Microwave Repair 2 09-13-2007 06:55 PM
LED Error Ch@r Dishwasher Repair 2 08-09-2007 11:46 PM
