larebear
#1 Posted : Sunday, February 13, 2011 7:29:20 PM(UTC)
larebear
The odor is like a bad ballast and the exhaust fan did not run when on a microwave setting (works when on fan only). I can't quite determine by sight/smell whether its the transformer (which I suspect) or if the magnetron can do that also when going bad.
But first things first - discharging the capacitor > the tag inside says short the negative terminal to the chassis ground > so simply stick a screwdriver into the neg terminal (white), and hit the frame? let the sparks fly? Does it need to be plugged in to discharge to the house wiring, or is that instead recharging the capacitor, and should it be done when unplugged?
abadfish66
#2 Posted : Sunday, February 13, 2011 7:32:01 PM(UTC)
abadfish66
make sure the microwave is unplugged when you discharge the cap... get 2 screwdrivers, put one screwdriver on one terminal of the cap and the other on the other terminals of the cap. now touch both driver shafts to eachother. You have just discharged the cap
Kenmore 80 Series washer, fast speed burning smell (Washer Repair)
by lwmi5870 3/9/2024 1:25:21 PM(UTC)
Washer has burning smell (Washer Repair)
by Underhill 6/21/2019 2:26:26 PM(UTC)
Burning smell when using convection oven mode (Microwave Repair)
by landonspop 1/23/2019 9:01:49 AM(UTC)
LG Washer Loud with Burning Smell (Washer Repair)
by bainters 8/24/2018 5:17:59 PM(UTC)
Direct drive washer burning smell- NOT the motor (Washer Repair)
by robmill3r 12/14/2017 7:32:32 AM(UTC)
Gas Dryer Burning Smell, Not Lint (Dryer Repair)
by andymcclure 10/9/2017 2:25:44 PM(UTC)
replaced tub seal, getting burning smell (Washer Repair)
by elocin71 9/4/2017 8:30:02 PM(UTC)
Kenmore 90 Series Burning Smell (Dryer Repair)
by AB81 4/26/2017 6:19:06 AM(UTC)
Burning smell and not pumping out completely - Whirlpool direct drive washer (Washer Repair)
by dwizum 3/16/2017 5:56:53 AM(UTC)
Burning Smell Possibly Electrical (Dryer Repair)
by pauly99 1/24/2017 7:46:14 AM(UTC)
Dryer Burning Smell (Dryer Repair)
by apphelp2888 11/27/2016 5:58:53 AM(UTC)
Kenmore Washer Burning Smell (Washer Repair)
by tfmj 9/13/2016 6:12:10 PM(UTC)
Whirlpool burning smell during agitation (Washer Repair)
by AE472 2/20/2015 6:24:29 PM(UTC)
Washer Motor Burning Smell (Washer Repair)
by CFB33 10/16/2014 7:57:05 AM(UTC)
smoke from starter/plastic burning smell (Refrigerator & Freezer Repair)
by ez211 10/13/2014 8:18:40 AM(UTC)
