Corinne Sayles
#1 Posted : Thursday, December 11, 2008 8:24:52 AM(UTC)
Corinne Sayles
The door frame to my microwave is cracking and is broken in a few spots around the handle. I purchased the replacement door from Sears. I have tried to take the door assembly apart by removing the three screws, but I have no idea how to get the outer door assembly off... HELP!!!
Thank you.:p
libertyappl
#2 Posted : Thursday, December 11, 2008 8:43:40 AM(UTC)
libertyappl
Corinne,
You will probably need to take the MW down and remove the outer case to access the hinge for the door.
Nat
Tyler33
#3 Posted : Saturday, December 13, 2008 7:48:02 AM(UTC)
Tyler33
I just received a new door assembly for my Kenmore microwave and spent about an hour searching for help with installation to no avail. I certainly am no expert, but managed to replace it by prying the small pin out with a flat head screwdriver and removing the door. I reused the pin (after straightening it), and it works great. Good luck!
Tyler
Thank you.:p
