I have a problem...with the Cook Top Light...( light that is under the microwave ).
I have changed the bulb...as I did two years ago....only this time it will not work any more...(Tried three diffrent new bulbs...yes, the right one ).
When it did not work...after that..I looked at the socket...it looked dried out....So, I ordered ...and replaced it. That still was not helping....still did not work.
Everything on the Microwave works fine...and can do anything with it...Just the light under does not work.
Is there a switch....that controls the light...other than the control panel ?
Is there a fuse that may have blown...when light blew out???
We would like to know....I needs to be fixed so we can see when we cook.
