| » Microwave Won't heat food and turntable doesn't rotate |
Model Number: JVM1533WD005 Brand: GE Age: 1 - 5 years
Tried to heat food in Microwave and it ran but didn't heat food. Also discovered that the turntable didn't rotate. Thru a DIY site I suspected one of the interlock switches was possibly involved. I applied a slight pressure to the door as it ran and it worked normally. Next I opened the microwave and checked that the latch was actually triggering the switches and they were being triggered. I used my resistance tested and the primary and secondary interlock worked normally. The interlock monitor switch never opened even with door closed. I took it out and ran the test again and it was opening when the switch was triggered, which appeared normal operation. I reinstalled it and the same result as initiallly found. The resistance test shows that the switch is always closed. Could there be another problem that I am overlooking? I am not an appliance guy but have a little knowledge of electric circuits and switches. I suspect the switch may not be the problem...Help me please.
Upon further playing with this microwave I now see the the problem in more in the latching mechanism. If I pull very lightly on the door as it's running, it functions normally. However if I just close it normally and run the microwave, it show the abnormal function. could something be out of place or worn out?
Quote:
- The interlock switch Part number: AP2024367 Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
| Display Modes | |
| Kitchen Aid Microwave Won't Heat Food | lmcalpin | Microwave Repair | 3 | 08-18-2010 07:17 AM |
| Microwave runs but does not heat food | newell | Microwave Repair | 0 | 08-24-2009 09:01 PM |
| Kenmore Microwave -No Heat, No Turntable -Related? | airheads | Microwave Repair | 2 | 07-14-2009 09:11 AM |
| Maytag Microwave Turntable will not rotate | asridhar | Microwave Repair | 0 | 06-15-2009 02:15 PM |
| Amana Microwave turntable and heat | rettakay | Microwave Repair | 0 | 05-18-2009 09:49 PM |
