| » ge dual wave II microwave inop |
Model Number: J HP62V OK2AD Brand: GE Age: More than 10 years
microwave over stove will not power up.
i have250 volts to what looks like the ac/dc power converter but no dc voltage going down to circuit board. Anyone know how to test ? Micro is completely dead Ads By Google Related Models |
I have the same problem with a GE JKP62G K3. First the control panel was dead. Replaced the 15 amp fusestat behind it. The control panel came back to life. I reset the clock - all good. When I started the microwave, the fuse popped again. Further investigation showed the high-voltage capacitor shorted. I replaced that, but now the control panel doesn't work. Seems like that last fuse-blowing incident caused something else to fail. The 220 volt circuit is OK - the lower conventional oven works fine. I *suspect* the high-voltage portion of the microwave is OK since I replaced the HV capacitor, but the low-voltage digital control panel is inoperative. I can't find 5 volts on it anywhere. Any ideas on what to check would be most welcome. Thanks.
Quote:
It may be a shorted high voltage capacitor or a shorted high voltage diode. Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first: How to Test The High Voltage Capacitor Used In Microwave Ovens How to Test The High-Voltage Diode (Rectifier) Used In Microwave Ovens (if it is NOT shorted, it's probably fine) You can usually find helpful exploded view diagrams and order parts by entering your full model number here. There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing. If you still have trouble, feel free to let me know. __________________ William E. Miller † prototech@usa.net Read more: GE Dual Wave II - Microwave "popped" http://forum.appliancepartspros.com |
| Display Modes | |
| GE Dual Wave Microwave System- original to house- 1986J | Rochelletx65 | Oven Repair (including Ranges and Cooktops) | 14 | 01-08-2013 02:43 PM |
| GE Dual Wave II microwave Model #JKP78G0K4 BG wont' heat | JayHan | Microwave Repair | 0 | 02-08-2010 02:21 PM |
| GE dual wave microwave | lwsears | Microwave Repair | 0 | 07-27-2009 10:17 AM |
| GE dual wave microwave system | rozman | Microwave Repair | 0 | 03-09-2009 08:04 PM |
| GE Dual Wave II - Microwave "popped" | gpdreier | Microwave Repair | 6 | 10-08-2008 09:27 PM |
