The surface light does not change between bright and night (bright on both), but off works. The low voltage transformer [DE26-20155B SLV-1350U(P)] is very hot, even when light is off. Is the problem a bad transformer? Surface light bulbs have full 120VAC on them, in both bright and night settings. Is this normal, or should voltage decrease for the lower setting? Or is the problem possibly caused by a bad switch or other part of the bright/night circuitry? Note that both surface lights very recently burned out, possibly caused by whatever failed, causing the above problem. Looking for any help. Surface light problem is not a major problem, and we can simply not use it, but I'd like to get it fixed. BTW, other parts I have purchased from your site have worked fine! Thanks.
