| » Microwave will not heat and makes slight noise |
Model Number: JVM1851WF001 Brand: GE Age: 5 - 10 years
My microwave did not heat very well one night and then the next morning it would not heat at all. I also remember resetting the clock twice the week before it broke. It also began to make a slight noise. The panel lights all worked. I turned off the breaker to the microwave and then turned it back on later. The part of the panel where the time is then showed strange characters on it. Does anyone know what might cause this and if it is worth fixing. I think it is a little over 5 years old. I cannot fix it myself but I would get repairman if it might be something small.
Thanks for any help. Ads By Google Related Models |
Check the outlet that the micro is plugged into. If it has a reset button push it. If that doesn't work flip the breaker, and if that doesn't work replace the breaker. A power surge maybe.
__________________
|[URL="http://delonghiespressocoffeemaker.com/"]DeLonghi Coffee Maker[/URL]| |
Could be a number of things.
Unless it is a top of the line unit, microwaves are now throw away. The labor alone to just open it up and take a look is often more than 50% of the cost of a new unit and it is not worth while putting that many dollars into it.
__________________
| Display Modes | |
| Microwave makes loud noise | CaboWabo | Microwave Repair | 8 | 08-11-2009 08:38 PM |
| Microwave makes loud noise when heating | avery2290 | Microwave Repair | 1 | 08-10-2009 03:48 PM |
| MICROWAVE makes louder noise and does not heat | dimark3 | Microwave Repair | 1 | 05-25-2009 05:29 PM |
| Microwave makes loud humming noise | aussie downunder | Microwave Repair | 1 | 10-20-2008 12:31 PM |
| Microwave makes loud humming noise | Fritzauf | Microwave Repair | 1 | 07-22-2008 11:39 PM |
