Discuss
Adjust door switches
 in
Microwave Repair
I have a GE Profile JE2160SF003 microwave, about 4 years old. It has worked fine until now. The problem is
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Adjust door switches
  #1 (permalink)
Old 12-19-2010, 07:18 PM
Junior Member
adsbar is on a distinguished road
Default Adjust door switches
Brand: GE   Age: 1 - 5 years
I have a GE Profile JE2160SF003 microwave, about 4 years old. It has worked fine until now. The problem is when I press start to heat, there is some clicking like usual and the microwave counts down, but the light does not go on, the turntable does not move, and the heating element does not go on.
Reading on this site, I opened the unit, and checked the fuse, which was intact. What I found was, the door switches seem to need adjustment. As I slowly press the door release, there are 2 clicks close to each other. If I just trigger 1 click, the microwave operates normally, but I have to hold it in that position.
Many posts have mentioned that you must adjust the door switches when replacing them, but I have removed the entire plastic housing for the switches and light, and have not found any adjustable parts. The switches snap in place, they seem to operate fine with a nice "click", and there is no play for adjustment of the plastic housing itself, just 2 screw holes. Am I missing something?
Alan
Ads By Google
  #2 (permalink)
Old 12-19-2010, 10:10 PM
abadfish66's Avatar
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
Sounds like you have a bad door switch causing the problem. But to answer your question on adjustment, with the door open just start the screws, but dont tighten all the way. Next, close the door then tighten the screws all the way....This is your adjustment.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
How to adjust door switch Macy Microwave Repair 2 11-12-2010 12:12 PM
Adjust Door mpche Dishwasher Repair 0 05-06-2010 03:06 PM
Install New Door - Adjust Interlock Switches hsinchienliu Microwave Repair 0 03-03-2010 05:07 AM
Microwave fuses & door switches davjones Microwave Repair 0 01-05-2010 05:05 PM
Accessing Microwave Door Switches candrewb Microwave Repair 0 08-21-2009 06:17 PM
